996 Turbo Forum 1999-2005
996 Turbo Gearbox/differential oil leak
Old 12-01-2017, 03:57 AM
mat59
mat59's Avatar
Default 996 Turbo Gearbox/differential oil leak
Anyone know what’s going on here? Have a small leak. Images below. Taken on right side (passengers side).
Thanks!
Old 12-01-2017, 12:14 PM
Macster
Macster's Avatar
Not the best views but if I had to guess I'd have to say axle flange seals. The ones in my 2003 Turbo's front diff developed leaks at somewhere around 100K miles. Tech replaced then and topped up the diff fluid level -- which fortunately wasn't real low -- and the new seals have been fluid tight ever since. Diff's ok too.
Old 12-01-2017, 02:53 PM
garrett376
garrett376's Avatar
Is that CHF, or trans oil? I'd bet your clutch slave is leaking.
Old 12-01-2017, 05:54 PM
Kevinmacd
Kevinmacd's Avatar
Looks to me the shift select seal is leaking, need to take the trans off and dismantle to fix it! The upper area where the select lever goes into the trans!
Old 12-02-2017, 02:31 AM
danspach
danspach's Avatar
Yeah, I have several very similar looking pictures from when I did my slave/accumulator.
Gear oil has a very distinctive smell and quite different from the Pentosin found in the clutch slave circuit. Swipe that drop off the trans and have a whiff. If it makes you go “whoa!”, then its gear oil. If not, Pentosin.
I’d bet it’s Pentosin and either your slave or accumulator is leaking.
Old 12-02-2017, 04:19 AM
911mhawk
911mhawk's Avatar
Yep, look leak above
Old 12-02-2017, 01:49 PM
jpflip
jpflip's Avatar
If you look at the second picture the leak seems to come from higher up and if you look at the picture of the engine on the bench , the slave can be the problem....
Old 12-02-2017, 02:08 PM
Kevinmacd
Kevinmacd's Avatar
Best thing to do is clean it all up thoroughly and keep an eye on it, to pinpoint the leak.
Old 12-07-2017, 01:29 PM
mat59
mat59's Avatar
OP here. It was the rear differential seal in the end.
Old 12-20-2017, 10:23 AM
mat59
mat59's Avatar
....and it’s not the axle seal after all. Turns out it’s the dreaded gear selector seal. Gearbox has to come out. Not great news. Now researching rebuilds as second gear synchro is weak. Makes sense to get it done whilst box is out.
Old 12-20-2017, 01:17 PM
Kevinmacd
Kevinmacd's Avatar
Sorry to hear it, thats what I thought! Good luck! Since it will have to be opened, maybe a second gear synchro replace or inspection, and pinion bearing inspection. Might be a good time!
Old 12-20-2017, 01:35 PM
32krazy!
32krazy!'s Avatar
997gt2 1-3 gear all steel syncros 1-6 gt3 shift selector send it to rader transmission cost is under 7k$ if you pull it and ship it. Add a wavetrac while your in there
Old 12-21-2017, 11:12 PM
mat59
mat59's Avatar
Thanks. Will take a look
Old 01-23-2020, 12:40 PM
mat59
mat59's Avatar
OP here - I'm updating this thread as it may be of use to others (I have a parallel one running on RennTech and both have been really helpful!). To recap, having originally thought the leak was from the axle seal, I had this replaced. It then continued to leak from a nearby area, which turned out to be the gear selector seal, which it would appear was due to the 'box being overfilled. However, I now have another leak from the same area! I've been under the car today and it's either the axle seal (again), or the clutch slave. I'm thinking clutch slave as there seemed to be a little fluid above the axle seal towards the top of the gearbox - hard to be sure as the fluid had mixed with some dust (I'm in Dubai...). Moreover, the reservoir in the frunk (green lid) is low. So, now I'm thinking I need a new slave cylinder!?
Old 01-23-2020, 05:13 PM
my04996tt
my04996tt's Avatar
Check the top of tranny with a white cloth, if it's green in color its the slave or accumulator.
Quick Reply: 996 Turbo Gearbox/differential oil leak
