All the washer fluid leaked out 05'TTS Cab
Washer fluid just leaked out from the bottom left front fender well.
Car has not moved lately; just found a puddle on the floor.
Looks hard to access that area; looked under the hood, and bottle /area is dry, so maybe it might be coming from the headlight washers.
Any easy way to find the leak? Never used the washers anyway
The entire windshield washer system, all plastic, had essentially rotted away and needed to be replaced, to the tune of around $800. That car would be roughly 3 years older than yours is now, however it was always garaged by its first owner and I am the second, also garaging the car all the time. So depending on how your car was stored all of these years, your reservoir and or plastic tubing could be shot and need replacement.
I've had the washer hose come loose on a previous 996... And my previous Cayman S. Not uncommon. They then intermittently **** blue washer fluid all over your garage floor. Should be pretty obvious what is wrong once you get access.
If that is it, it is easy to re-attach, though a bit of a pain to jack up the car, remove the tire, loosen the wheel liner, etc....
