996 turbo wheel bearing....sensor inside?
The later 997 cars use a magnet in the wheel bearings for abs. These cars no longer use a toothed ring on the tension bolt. It’s smooth. 996s do NOT use a magnet. Install the bearing how you see fit..
'rubber' side out, metal side in
