Making custom brake ducts - backing plate?
So after taking my car for some track events this fall, I have decided that I need to do some brake upgrades. Since I got the car a few months ago, I did the following for setup: factory calipers w/ spacers, 350mm rotors, pagid yellow pads, GT3 ducts, GT2 fender liners, and Motul 600 fluid. I ran factory turbo twists on 245/645/18 and 305/645/18 Pirelli DH slicks. My local track (PittRace) is kinda hard on brakes and with the slicks it made it even worse. During the last 5-10 minutes of a 30 minute session I was getting a lot of brake fade and pedal mushiness. Brake fluid was boiling as a very small amount would make its way out of the reservoir cap and pool around the top edge of the reservoir. I was driving with PSM on most of the time and I feel that this was a mistake and lead to increased brake usage by the car and quicker overheating of the braking system. I was just getting used to the car as it is relatively new to me...so somewhat rookie move there and also a bit of a safety net.
That all being said, my plans for upgrades while the car is garaged for winter are:
-rebuild stock calipers (they look pretty worn from years of use. Car is new to me so I don't know their history)
-keep using pagid yellow pads
-SS braided lines
-Castrol SRF or Endless RF650 fluid
-custom brake ducts
So...on the topic of cooling. I have the basic things - vented fender liners and GT3 ducts. I'm not interested in the GT2 ducts and I don't they'd provide a significant improvement. I have thought about the 997 GT3 air guides, but thought - why not take it all the way and custom make fully functional air ducts that shoot air directly onto the rotors? This should be the most effective cooling mod possible.
The only two commercial products I have been able to find are http://www.pelicanparts.com/catalog/...BRKPRF_pg1.htm and https://www.scuderiacarparts.com/aft...c-bd5900t_8224
But why not make my own? Seems easy enough. I'd like to model it off of this: https://gallery.rennlist.com/gallery..._shroud?full=1 But continue it all the way to the rotor instead of having the ducts feed into the fender wells.
Now does anyone have any leads or sources for a backing plate that I could use as a base for this project? The Cantrell and Cargraphic ones look like pretty crappy quality and are very expensive. The rest of the project is relatively easy routing of hose. Should I just secure the end of the hose to the wheel carrier/hub, aimed at the rotor? Any other ideas or feedback regarding this idea??
-SS braided lines
-custom brake ducts
I can tell you that your psm cooked your brakes. Your current setup should be fine for 30 min track seasion but with the psm on, the traction control is constantly braking on track. Well even with it off it still does a little. Only true way to turn it off is unplug it at the abs pump.
not to say that more brake cooling wouldn't help but 95% of your issue was having the psm on
Even if you're right (which I hope you are!), I'm still going to take the opportunity this winter and get as much cooling in there as possible. Nobody has made custom brake ducts? Is there a reason besides that it's unnecessary? Am I pursuing this for no good reason?
You're pretty confident that I wouldn't have any problems with overheating if I completely unplug PSM next season? I really hope it makes that big of a difference.
as for ducts, if you have gt2 front liners, they push more air to the front already as well. You could add a custom duct for a little more but most likely not needed.
for the rear though you can add the 997 gt3 stuff.
message pwdrhound, he can get you part numbers for everything you need. John is put these cars through more bell on track than basically anyone else and has also tried about ever combo of stuff made. He knows his ****.
This is what you can use for brake cooling. You won't do any better trying to reinvent the wheel. Most is direct bolt on and some required a little modding. About $1200 or so in parts. In the rear you can use the 996GT2 brake ducts which work well but not quite as effective as the 997 stuff.. Use SRF or Endless 650 and PFC pads. I don't like Pagid. Don't waste your money on SS brake lines, useless upgrade, nothing to be gained there.
Front:
996GT2 front liners with enlarged cooling duct opening
996GT2/Cup brake ducts
997GT3 upper air guides modified to fit 996 coolant pipes
Rear:
997.2GT3 rear brake ducts
997GT3 caliper air ducts
997GT3 caliper air guides
Front:
Rear:
rear under tray: 997.504.629.92
rear brake ducts: 997.575.183.00 and 997.575.184.00
rear brake spoilers: 997.331.487.02 and 997.331.488.02
