New GT3 RSR headlights arrived!
Install pics nxt week.
Quick recap of the new light system: 996 TT oem headlights rebuilt & modified with the following;
clear projector lens for main projector vs. oem frosted unit.
Boosted tuned Hella ballast to 46 watts.
New Phillips high output HID bulbs.
oem H3 fog projector replaced with 3000k Morimoto HID projector operating off the oem fog lamp switch with separate ballast.
OEM NLA GT3 RSR lenses.
OEM headlight washer pop up stalk delete performed.
LED turn signal system installed.
Full satin black paint job completed for the oem interior housing.
I had them built here:
https://rennlist.com/forums/996-foru...build-log.html
I didn't see a price in that thread. What did it cost?
Each build is different depending on what components u select to upgrade + paint + labor etc. The RSR lenses were ~$300 smackers.
Contact Evan Patak @ Vision Auto Labs for ur quote.
Good Luck
Good Luck
Cant wait to see them installed! Might have to send mine out for some upgrades.
Also new Toyo R888R tires getting installed along with rear fender roll.
Its almost done. Headlight install this week.
gt3 spindles? if so then you need gt3 rotors not 997 turbo rotors . different offset. same for the coilovers due to the oiffset from the awd axles
Ok, those are some sweet mods. Should be well worth the wait. Which JICs did you go with? I believe there are 4 different versions?
