996TT Spacer recommendation
All,
I’d be grateful for recommendations on what thickness spacer to use front and back on my 996 turbo. I’d like to widen the stance a bit but nothing too silly. The wheels are:
8.5x19 ET49
11x19 ET40
Also does the quality of the spacer brand make any difference/any recommendations on decent spacers? The car will see some track work and high speed runs.
Many thanks,
BJ
8.5x19 ET49
11x19 ET40
Many thanks,
BJ
I fitted FVD hub centric 15mm to the rear and 7mm to the front. Rear looked much better, in my view. Didn't think much of the front, so took them back off, after noticing a minor vibration through the steering.
Sorry can't help with a comparison of other brands, hopefully others can chime in.
I just bought the 8mm and 15mm kit from ECS, was very impressed with the quality.
The main thing to look for is that the ones you get are hub centric so they stay aligned properly and so does your wheel.
All thankyou for the advice/info, much appreciated.
Being in the UK I think I will go with FVD's 15/7 combo as they do a full kit in black (I have black wheels).
So from the above, will I definitely have to roll the fenders with these spacers?
Many thanks
Many thanks
Hi, I'm running the tyres that came with the car (8.5" and 11"). Currently 235/35/19 and 295/30/19. MPSS.
I'm happy to roll the fenders. Will probably end up doing Powdrhound's GT2 liner tip when I get some proper 9"/12" wheels
