Boost Leak Question
Boost Leak Question
So I noticed I was only getting about half boost at the track this weekend and have traced it down to where the F-Hose connects to the aluminum intake (see below) - when I try to pressurize the system it comes directly out of that hole connected to F hose.
Since I just had the diverters out I am guessing one of the check valves is bad? Any other ideas? Thinking #45 and #21 in the diagram
if you need chack valves i have some that are the same cracking pressure with nytil valves i can send you. pennies compared to oem cost. just send me your address. i bought like 15 of them for half what a single c/v from porsche cost
