PS Hydrolic Fluid / Line
Well, seems like the line near the coupling is leaking fluid. Not sure how long it has been leaking. So far no difference in the car. I did check the cap and the stick indicates it needs fluid.
1) Is the picture the right fluid?
2) Can the (looks like brass) coupling be replaced without the line. I can't imagine how difficult it would be to replace the whole line. If coupling replaced how difficult. I can see only the airbox and pulley are in the way. I am sure it would be a messy job with fluid to replace.
3) Anything I can do to "patch" or just a little fluid can leak.
Generally the line coupling is such a part of the line the coupling is not replaceable separately. For instance the item you have connected to "How to separate from line?" is crimped to the hose and is not replaceable.
You might be able to remove the line and along with it the leaking connector/fittings and take the hardware to a shop that specializes in hydraulic line repair and have something done. I've never had to do this and in fact I can't ever recall having any problem with a hydraulic line of any car I've owned.
Otherwise you are probably facing replacing the line. To remove for repair or remove to then install a new one could be a real job. Worst case -- just saying -- could require the engine be removed. But your best source of info on this would be a senior tech at your local Porsche dealer. He can advise you regarding repair vs. replacement and what amount of work it is to remove the old line and either reinstall it after repair or installing a new one.
It's a press fit, you slide the collar in and the line pulls out. The issue is the HOSE not the receiving end.
That line is an SOB and it might be able to be done w/o the motor drop but it's a LONG hose and well, it'll be expensive.
And, after a while, they will ALL SEEP. The vibration from the motors weakens the joint/seal.
My advice: if it's not dripping and just 'sweating' keep it clean and leave it alone until you have a reason to drop the motor.
Thanks for all the responses. I was afraid the coupling and line does not separate. Yes, it is more like 'sweating'. No way I am going to drop the engine $$$$ unless the car is not running right.
I am guessing at these cars start to get older the weaknesses are starting to show up. I will be on the track this weekend and will monitor how much fluid comes out. The last thing I want is to spin in my own fluid or cause issues for anyone else. I am guessing/hoping the amount of fluid that comes out is going to be minimal. Again, I really don't want to take the engine out (again) unless I have to. I would think someone could come up with a creative was to seal/minimize the fluid loss.
