996 GT2/GT3 Forum 1999-2005
Clutch Face to Engine Block Dimension
Old 04-03-2017, 07:36 PM
Ray Hall
Ray Hall's Avatar
Default Clutch Face to Engine Block Dimension
Hello Everyone,
I have a G96.50 gearbox I am going to use with the Audi V10 engine from the RS6. I am making an adapter and flywheel. The clutch I am using is the GT2 that is used with this gearbox.
I need a dimension from a 996 GT2. See attached image. Can anyone help.
Ray.
Old 04-05-2017, 06:58 PM
Ray Hall
Ray Hall's Avatar
Looks like no one has this knowledge. Is there any other forum or place that may be able to answer this question.
Ray.
Old 04-05-2017, 09:22 PM
AudiOn19s
AudiOn19s's Avatar
I think you are overlooking some variables here.
that measurement you outline below is 36mm (+ or - 1) for a car equipped with a single mass flywheel.
Dual mass flywheel is obviously going to be different.
Old 04-05-2017, 10:15 PM
Ray Hall
Ray Hall's Avatar
Hello Addict,
Thank you for the information.
Why would the dual mass be different. I would have thought the throw out leaver and slave cylinder push rod would need to be modified if the single mass was different.
I am no Porsche expert, but have replaced dual mass with single on Lexus engines and the single mass has the same clutch face distance, so no change needed to lever and push rod.
Ray.
Old 04-05-2017, 10:34 PM
AudiOn19s
AudiOn19s's Avatar
Originally Posted by Ray Hall
Hello Addict,
Ray.
Single mass is thinner than the dual mass setup. That measurement you are looking for will be different between the two
The slave cylinder, rod for the slave and fork that actuates off of the slave are all the same parts no matter the flywheel.
The difference is in the length of the "arms" on the release bearing. The dual mass flywheel has very short arms on the release bearing. The single mass uses a release bearing with longer "arms" to offset the difference in thickness of the flywheel.
Guide tubes are also different lengths between single and dual mass setup.
All else is the same.
Don't have dual mass components or I would measure them for you.
Old 04-05-2017, 11:30 PM
Ray Hall
Ray Hall's Avatar
Helpful information.
I am using a pressure plate for a single mass flywheel so will make sure I get the correct release bearing carrier, so your 36mm is correct.
Ray.
Old 04-06-2017, 09:10 AM
AudiOn19s
AudiOn19s's Avatar
Just for reference, pressure plates are all the same too from a dimension standpoint.
Here's the standard release bearing
Here's the throw out bearing for the LWFW with longer "arms"
Old 04-06-2017, 05:53 PM
Ray Hall
Ray Hall's Avatar
Thank you for all your help. I has cleared up a lot of things I was unsure about.
Ray.
Old 04-10-2017, 04:45 PM
rbahr
rbahr's Avatar
Let me know if you need the DM measurements - have an old one at home tucked away.
Ray
Old 04-10-2017, 06:09 PM
Ray Hall
Ray Hall's Avatar
I am not sure what is the correct dimension after talking to a company in Australia who build and race Porsche cars. They said the 36 mm sounded wrong and believed it was a lot less then this. If you could give me the DM measurement, I could workout the SM measurement.
Ray.
Old 04-10-2017, 07:58 PM
AudiOn19s
AudiOn19s's Avatar
I didn't pull those measurements from a manual, I crawled under the car and measured.
It's a little tough to see but the clutch surface is just a hair past that second ring gear. With light shining the best I could you can see the surface then the dark clutch material. Sorry, not pulling the pressure plate off its already in enough pieces as it is
Old 04-10-2017, 08:01 PM
AudiOn19s
AudiOn19s's Avatar
Single mass vs dual mass. I can't remember if the back of the crank is flush with the block. So you'd have to measure the distance from the crank mounting point between the two.
Old 04-10-2017, 08:22 PM
Ray Hall
Ray Hall's Avatar
Well....that looks like 36 mm to me. Picture tells it as it is.
Thank you, and sorry for the doubt.
Ray.
Old 04-10-2017, 09:06 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Old 04-11-2017, 09:05 AM
AudiOn19s
AudiOn19s's Avatar
Ray.
No problem. Best of luck with your project!
Quick Reply: Clutch Face to Engine Block Dimension
