Wheels for 996 GT3 with Brembo GT 380mm rotors?
Today I went to install OEM 996 GT3 wheels on my car an was surprised that the wheels didn't fit. Calipers rubbed on barrels on the front. Currently 18" Fikse Profil 10 wheels are on front with non matching VE's on rears that were installed by previous owner. I've only owned the car for a month and now I get why wheels were not matching. He had problems with the Fiskes leaking and broke/bent/leaks 3 rear wheels in 2 years. What other options in wheels do I have besides getting two rear Fiske wheels to match? What are other GT3 owners running with the Brembo GT brakes up front?
I would have thought you would need 19s for those rotors? could you not take the wheels from the 997?
or a motorsport wheel in 18s like BBS or compomotive. BBS always have good brake clearances. you could run hubcentric spacers (they bolt to the hubs - not sit on them) to help clear the barrels and widen the track a little. not ideal but cheaper than new wheels all round. you will need longer wheel bolts if you go out further than 5mm or even go to wheel studs. |
They will fit under certain 18s - BBS E88, Fikse, Forgeline, some monoblocs and some others. It's a tight fit but it works. Your measurements have to be spot on and you have to be cognizant of the offset relative to the drop center of the wheel (and different brand barrels have different drop centers for the same width barrel). Used to have the same on my old 996tt with 18 Fikse FM10s and FM5s.
Originally Posted by Boostin
(Post 11958331)
rgee27 I have a set of Fikse Profil 10 for sale but think the offsets are not right for your car. were recently resealed, retorqed and checked out fully, completely straight and do not leak.
Not sure why the PO was bending them, these are strong wheels. I did bend 2 inner rings but that was a nasty spin that caught the inside wheels on a curb on track (no other issues, glad wheels took it vs. other parts!). I had no idea they got bent util I swapped tires, and the bends weren't bad, but did replace with Fikse new parts/bolts. I run Brembo type3 380 rotors with porsche factory pccb calipers on my 997.1 RS These are the build specs: 428811 18" Profil 10 Mesh F722A11-3692 220810 Outer Rim 1.0 X 18 20 Hole 2 221880 Inner Rim 8.0 X 18 20 Hole 2 Front = 9.0 X 18, +51mm Offset 448811 18" Profil 10 Mesh F724A11-3694 220830 Outer Rim 3.0 X 18 20 Hole 2 221890 Inner Rim 9.0 X 18 20 Hole 2 Rear = 12.0 X 18, +44mm Offset |
Originally Posted by Spyerx
(Post 11963178)
rgee27 I have a set of Fikse Profil 10 for sale but think the offsets are not right for your car. were recently resealed, retorqed and checked out fully, completely straight and do not leak. Not sure why the PO was bending them, these are strong wheels. I did bend 2 inner rings but that was a nasty spin that caught the inside wheels on a curb on track (no other issues, glad wheels took it vs. other parts!). I had no idea they got bent util I swapped tires, and the bends weren't bad, but did replace with Fikse new parts/bolts. I run Brembo type3 380 rotors with porsche factory pccb calipers on my 997.1 RS These are the build specs: 428811 18" Profil 10 Mesh F722A11-3692 220810 Outer Rim 1.0 X 18 20 Hole 2 221880 Inner Rim 8.0 X 18 20 Hole 2 Front = 9.0 X 18, +51mm Offset 448811 18" Profil 10 Mesh F724A11-3694 220830 Outer Rim 3.0 X 18 20 Hole 2 221890 Inner Rim 9.0 X 18 20 Hole 2 Rear = 12.0 X 18, +44mm Offset
Good to hear you got it all sorted. I forgot to mention that Alan is a great resource over at Fikse for parts, wheels, questions, etc. He's based in the US so am guessing you probably didn't meet him but a good resource for future reference.
I've got a couple sets of Fikses for my 6GT3 and that's all I run at the track. I've bent a couple inners from track incidents but they're actually very easy to replace and reseal assuming you have a torque wrench, patience, and order up the right adhesive / sealant. I haven't had any problems with them leaking after resealing either. Also, you can order barrels from Forgeline that fit (I had to go this route when Fikse was going through some troubles before getting acquired by Kodiak). |
