996 GT2/GT3 Forum 1999-2005
Question on GT3 shocks & cup car shocks
Old 11-13-2014, 12:21 AM
rbahr
rbahr's Avatar
Default Question on GT3 shocks & cup car shocks
Hi All,
Can someone tell me the differences in length - say total elongated or compressed between the street 996 GT3 shocks and the 996 Cup car shocks?
Ray
Old 11-13-2014, 04:49 AM
pete95zhn
Basic Site Sponsor
pete95zhn's Avatar
I have the info at home, will post it during the weekend. I'm now in Japan.
Pete
Power. Lots is good, more is better, too much is just right...
'87 951, RIP
'00 996 C2 L92U AQ / IXAA IXRB IX54 M96/7.xx G96/7.88 M030 M375 M376 M436 M476 M601 M983 ... + 991 GT3 brakes, 997 GT3 sway bars, fully monoball'd suspension, Bilstein Cup Car coilovers, do88 Big Pack ICs. 10 & 12 x 19" BBS CH-R wheels with 265/30 & 325 /30 -19 MPSC2s.
Old 11-13-2014, 09:09 AM
rbahr
rbahr's Avatar
Thanks Pete
Ray
Old 11-13-2014, 11:49 AM
IPguy
IPguy's Avatar
Tim Olsen can help as well, he switched my 997 JRZs to 996 fitment, the rear shock bodies are different lengths, as likely are the 6 cup.
Old 11-14-2014, 12:47 PM
pete95zhn
Basic Site Sponsor
pete95zhn's Avatar
I have a partial answer, just rears measured:
-Piston length, from the top of the body to start of threads:
Cup 120mm, GT3 170mm
-Shock body, from the top down to middle of the attachment bolt hole:
Cup 220mm, GT3 230mm
-Piston's top threaded part is equal
(Bilstein 3-way adjustables, AFAIK early Cup)
IMO fronts are of more or less equal length, or at least the difference is insignificant.
Old 11-14-2014, 01:17 PM
rbahr
rbahr's Avatar
Hi Pete,
Thanks! Sorry for the dumb question, but I need more rear shock travel due to the changes I made and the ride height I want. I need to shorten the ones I have. The Cup car heights is probably a good place to be. I also want to lighten the springs a bit - after I get the bum steer set :-)
Are you saying that the overall difference in length is 10mm or 50mm or??
Old 11-14-2014, 02:49 PM
pete95zhn
Basic Site Sponsor
pete95zhn's Avatar
OK, my bad...the total difference is 60 mm. Basically max available piston travel is 120 mm, without the bump stop. Even a Cup uses one. The trick is to spec springs so that car sits at wanted piston position when stationary...
I have rather mild spring rates, so only a main spring (HRF 200-60-120) is needed. With stiffer springs you'll need a helper too.
Quick Reply: Question on GT3 shocks & cup car shocks
