Pole Position Seat
Pole Position Seat
I have a PP seat from my ex 964. Can I bolt that straight into the 996 GT3 or does it require different sliders etc? Also where do the eye bolts for the left/right/and substrap harnesses go. Are there factory screw in points designed into the car already? Is the standard seat belt (female end) attached to the body or to the seat itself. Hoping I can install the PP seat and still use the standard seat belt set-up along with the track harnesses when needed.
Many Thanks for your input.
Chris
Chris
GT3 player par excellence
not sure on sliders
female side buckle is attached to seat, lap belt can be bolted to seat with same bolt that bolts female to seat
door side lap belt can be stoned to eye bolt on door side of seat. I also seen it bolted to lower bolt of oem seat belt bottom of b pillar
