996 GT2 Wheel Fitment
Hey,
Sorry to ask but are there any 996 GT2's running the following set-up?
Front: 18 x 9 48mm offset with 245/40/18
Rear: 18 x 12 40mm offset with 305/35/18
If so do you have fitment and rubbing issues? Any Brake Clearance issues with PCCB?
With those offsets they fit the car well and provide an aggressive setup. The tires are bigger than OEM in diameter but they still fit.
In more detail, rubbing etc. depends on alignment and ride height but you are good to go. PCCB fitment depends on wheel style, but the vast majority of 18" wheels fit the brakes well and I wouldn't worry about it as those offsets already tell they are made precisely for 996 GT2.
should be fine, rear will probably need a bit of extra camber- 'track' specs should be good
