Softronic Vs EvoMS
inteereresting. i driven many of EVOMit cars. great stuff indeed.
but i like the oem throttle response,
can it be retained but increase high end hp. i dont care about hp under 7000 rpm. i run 91 oct
will this require a special tune or will it be a standard tune that sharkwerk can load to my ecu.
thanks for the kind words fellas and indeed we tailor those tunes to however your driving style is. I know a lot of you prefer the stock pedal maps/throttle and that's easy. Some want left foot braking enabled. Easy... Some want 93 octane.. easy Also as I tell everyone out there... if for some reason you don't like it we'll gladly return it to stock. Todd/we want people to be happy and keep on having fun so. I can tell ya it works very well... Here's us doing some fun stuff on our 996gt3 back in the day:
It's super easy to remove the ECU (skip ahead of the bose subwoofer since we don't have that crap in GT3s):
http://sharkwerks.com/porsche/techni...s-gt2-gt3.html
GT3 player par excellence
^ nice. now make my 4.2L
Actually during R&D been there and tried it. Personally I didn't like the small extra bit of low tq for the loss in rev/character due to the heavier 105.4mm pistons . Didn't rev/accelerate as nicely as with lighter ones So for now you can have the duramax 4.1
http://www.sharkwerks.com/products.php?pid=189
Former Sponsor
The tuning is all performed through the same procedures at our EVOMSit Partners like Sharkwerks and others around the country as it is through us directly, just different means to get the files to Todd to be tuned. The same tune and same options are available wherever you go.
Sam
Former Sponsor
Sam, I don’t intend to be contradictory but according to the DME 7.8 manual the primary purpose of the O2 sensors after the cats is to measure the efficiency of the catalytic converters. You probably have seen the parameter “mean amplitude after cat 1 or 2”. This looks at the amplitude of the secondary sensors to measure the oxygen storage capacity of the cats. Without cats installed the signal of the secondary o2 sensor will look like the signal of the upstream sensor which is an indication that the cats are not doing their job and should throw a CEL. Please see the attachment. Yes, the secondary sensors do provide some feedback for the upstream sensors as you stated but this is a secondary function. Your tune must be bypassing the cat efficiency test if no CEL is triggered.
I haven’t loaded the Euro II program on the GT3 but I have on a 996 DME 7.8 and it ignores the signal from the secondary sensors.
The first tactic is to use HFCs, and use HFCs that actually work if the car is to be driven on the street. Exhausts that use good high flow cats, like the Fabspeed, Tubi, Akrapovic, etc. (I realize not many of these make replacement cats for the 996 GT3 any longer) cost more, but you get cats that do their job and don't fall apart after heavy track use. For track cars or for people who don't care about emissions/the environment, this is a moot point.
The second tactic is in some ECUs and programs, we can alter how the ECU compares the secondary signal to the primary, and what threshold it uses to determine that the cats are working/not working. This is cool because it allows the car to set catalyst readiness, which is important for getting the car through OBD-based emissions, and allows us to keep all the other functionality of the secondary sensors working as it did from the factory.
The third tactic is to simply disable the readiness test. This is no bueno for cars going through emissions, but if the car never tries to check efficiency of the cats it can never fail them.
Sam
For the record, my EVOMS 'stage 2'(circa 2007) GT2 has secondary O2 extenders on it to pass emissions scan/read-outs, has a Milltek exhaust with cats...
We use three tactics to avoid CELs on catless/HFC cars.
Sam
Sam
Understand that completely, added the part about my O2 extenders due to the above from EVOMS about passing emissions.... what I want to hear more about from EVOMS is the idea of scanning AFR's primary vs. secondary, and having fuel trim adjusted by the secondary's, interesting to see some documentation via Bosch about this function
Evoms with confidence, I have it in all my cars, and Todd does great work with the GT3s as well.
Sharky is proof of it. All my clients with carless headers and M&M exhaust have an Evoms tune, and I have proof if compared with different files as I did it back to back on the dyno with same hardware.
Guys don't only focus on the top end power, which you will gain, don't get me wrong, but also on the smoothness and power under the curve.
just my 2 cents.
just my 2 cents.
