GIAC ECU flash good or bad?
I'm interest in a particular GT3 and it has a GIAC ECU flash and I've read that the GT3 doesn't need a flash so I'm wondering if I should pursue this car any further. Any thoughts?
Chuck I'm really not interested in any performance gains as I would prefer the car to be untouched and stock. It's just that I've read that changing the ECU shortens the longevity of the engine.
I think giac tune can be removed via obd 2 and returned to stock. It's not the type where u send off the ecu box and they install a new chip in it. Mike
I wouldn't see a flash as a bad thing. GIAC is one of the biggest names in the tuning world. The only way tunes can hurt motors is mainly in forced induction cars and usually that's when a smaller company is doing custom tune work to try to squeeze every last hp out of the tune in question.
The bigger companies "standard" tunes might be a little more aggressive than stock but are still safe. Plus the Bosch moronic ECU in our cars does a very good job of cutting power and timing when it needs to. I've had a GIAC flash in my Audi A4 turbo for most of its 220k miles
Back to the GT3 specific platform. I think most of us see tuning as "bad" in that it's just not a great buy from a cost benefit standpoint so most avoid it. Money is much better spent in other areas on our cars.
GT3 player par excellence
that's big money for a 996.
i would want it to be beyond perfect.
to me, any ecu once touched, i will not buy it.
that's just me.
i dont care how good it is is. i wont touch it.
no, it's not bad, but its not worth 65000 anymore in my book
that's just me.
I ask as companies like EVOMs etc get great reviews on their flashes and are installed/ recommended by some of the best tuners.
Why would this then be a no-go for you?
factory tune is always best.
unless you personally turn the car into an all-out proposition which needs a tune to accomodate
cams, fuelling, heads, intake, exhaust mods.
and to the OP. at 60+ for a 33000 miles 996gt3, i would expect absolute perefction. it's above mkt price.
I know Audi has tuned some of their cars lean from the factory because of the reduced emissions, which isn't good when you are pushing the car hard. A good tune will improve engine reliability over stock, a bad one will make it worse. Not sure if Porsche plays the same tricks.
