Does street driving impact heat cycles in R compound tire
#31
#32
What pressure did you start them out at Franc? If you saw my Kuhmos post a few months back we had blisters formed on sidewall from starting out the tires ie prewarm up - at too low a pressure, which we do with Dunlop and Michelin, but the Kuhmos sidewalls were compromised in those first few (hard) warm up laps and ended up blistering - I think 4 tires in one session on 4 cars - later. Now we start them harder, come in sooner and deflate a bit so we never drop down to 1.6 bar anymore with those - maybe something like that?
#33
I was at the Glen last weekend and there was a Khumo that started to delaminate as in the picture. Heard from another club member that it also had happened to him. Seems to be a common failure. I believe 2nd member got some monetary compensation from Khumo.
#34
I remember reading about delam issues when starting pressures are set too low, but IIRC it was for slicks. Perhaps call Nitto and see what kind of response you get; they are pretty responsive to the few emails I've sent. Many running them here, but this is the first I've heard of such an issue. GL and keep us posted.
#37
Any of the Mich PSS 18" combos below will work ABS wise and can be made to work using sway bars. My attempt below to 'classify' the setups.
1) 225/40, 285/35 (street setup)
2) 235/40, 285/35 (street / track)
3) 245/35, 285/35 (track / street)
4) 255/35, 285/35 (track)
5) 265/35, 285/35 (autocross)
