difference between cup engine mount and rennline engine mount?
Hi,
i was wondering if there is a difference between cup engine mount(blue color) and rennline engine mount?
both are solids.
thx
both are solids.
thx
i was wondering cause the gt3 im looking to buy has those blue solid mount, and i was told it was cup mount.
and i have a brand new set of rennline solid mount and i was wondering if i should put them in the car instead of those blue mount...
anyone can help?
anyone can help?
The blue mounts are from TRG
http://store.trgparts.com/engine-mou...996-p3819.aspx
why would you replace them unless they are worn out?
i dont think they can really worn out since they are solid....
i was just wondering if the rennline mounts are the same and if there would be a benefit over the*trg* mounts..
Those mounts do not have many hours on them but they can wear out by having the holes become oval. Actually any solid mount is more likely to wear out faster than the oem.
I'm not sure that I would go with full solid in the back and rubberized at the gearbox... but that's just me.
Don't quote me, but from memory, I think that the cup is a different set up as the blade is different??? I would need to check.
