GT3 calipers and pads to suit
Guys,
When you convert from PCCB to steel rotors what pads are you putting in the rear, are they the same as the normal GT3/turbo steel pad or are they a larger pad due to the 350mm rotor?
Also I am looking for a new or excellent condition red (steel) right hand front 6 piston caliper, so if anybody has one for sale please PM me.
I don't think the pads are different sizes for PCCB vs. steel; only the compounds vary. I have converted to steel rotors and I run the stock, steel rotor, street pads when I am not driving on track.
When on track, I run the stock 996 GT3 pads sizes from PFC
Are you sure you're looking for a red caliper? PCCB calipers are Yellow.
So just to confirm the stock steel 996 GT3 rear rotor on the 04 cars are 350mm and I jusy need GT3 steel pads?
Basically I am upgrading the brakes on a 996tt and I am keeping them steel, I need a RH front 6 piston caliper plus I am looking at buying a set of PCCB rear calipers and painting them red so I can run 350mm rear 997t discs.
Admin
Steel
350 mm x 34mm front
330 mm x 28mm rear
cross-drilled and vented
PCCB
350 al around and 34 mm (front), 28 mm (rear) thickness
