Need wiring help 996 GT3
I'm trying to install a 6-pole battery cut-off switch in time for the club race at the end of the month. I can't figure out from the factory wiring diagram which wire goes to the No 2 poles. The instructions show the switch interposed between the ignition switch and the "ignition coil", but these cars don't have a single coil.
Could someone with this set up check for me to see where the switch gets its wire from the ignition circuit?
TIA
If no help available, I'll have to let the shop do it for $$. I'd rather spend the $$ on more Hoosiers.
TIA
