2004 GT3- getting camber at rear - how?!
I am looking for some adjustable LHS rear wheel control arms for my 996 2004 GT3 CS
I am starting circuit racing & we need to get more camber into the slick tyres to make them work - ie get hot!
Apparently - the standard arms on a road 996 GT3 just won't give enough camber adjustment.
will 996 GT3 Cup (or 996 RS?) arms do the job?
Appreciate any insights/parts available
thanks
thanks
Are u running stock suspension? On slicks optimal is upgrading too 2 or 3 way adjustables. If not rotate struts in combo with shims and revalving stock shocks and springs plus ancillaries. Mike
Workshop says we still dont have enough camber thou for slicks - so need more adjustable control arms - shims etc wont do it.
- ideas?
You really need to be looking at upgrading the control arms to fully adjustable. I would also go with using monoball inserts on the bottom arms & an adjustable toe arm that uses the Cup locking plate to lock off the normal eccentric adjustment which I've found will move when the rest of the suspension is using solid bushings.
GMG / Tarett / RSS all make the appropriate hardware.
Is there an official guide to adjusting the upper control arms if you've got the adjustable ones on your car?
My car has adjustable uppers on it, but they are set to stock length. My car still uses the eccentric bolt at the bottom for camber adjustment (I've got locking plates for toe, not camber).
My impression of the upper control arms (dog bones) is that when you start to deviate from stock length you start messing with the bump curve on the car and can really throw it off. They're primarily on my car to get rid of the rubber from the stock arms.
Even with the aftermarket upper control arms on my car I think I'd go with 2 piece lower control arms for the rear like the front has if I were in search of more camber.
This is the type of product you want if you are going 'racing'
http://rss.rpmware.com/rss/rss_tarma...s/g-62403.aspx
- camber is adjusted with shims (comes with kit)
- comes with 3 holes and solid caster pucks for playing with caster to fit your tire in the correct spot
- comes with solid monoball
I have them on my 997Gt3
That said, I am not aware that a 996gt3 is not able to get whatever camber is needed front and rear with all stock parts.
In the front, you have to rotate the front strut tops and then shim to bring caster to spec for large camber values - in the rear, there should be lots of adjustment available.
The advantage with the 2pc type arms (RSS, OEM, other) is that you can get them with monoballs, solid caster pucks, and the 2pc design allows the use of shims that remove the likelihood of camber changing because the eccentric doesn't hold
Th said, I am not aware that a 996gt3 is not able to get whatever camber is needed front and rear with all stock partsat.
RE: That said, I am not aware that a 996gt3 is not able to get whatever camber is needed front and rear with all stock parts.
sadly - post kissing a concrete wall - just cant seem to get enough camber on the LHS rear wheel.
Workshop confirmed details as:
996 Cup Car parts - for LHS rear wheel
Left and Right hand lower arm assemblies.
996 331 053 90 left wishbone assembly
996 331 054 90 Right
that seems what you are suggesting?
cheers
I was running the street GT3 / RS lower control arms..
996 341 121 90 L
996 341 122 90 R
And matching them w/ the Tarett Engineering monoball ends.. and while at it, added the Tarett's adjustable caster bushings as well.. (see pic above)
996 341 121 90 L
996 341 122 90 R
