Enclosed trailer question...
Check out this place. http://solarestrailerssite.com/custom_trailers
They do just about anything you want and are not an arm and a leg. Good quality trailer and you can option it out without it costing a small fortune.
When I went shopping for trailers I started at the smaller size and realized there was NO WAY to get a GT3 on properly to distribute the weight for optimal tongue weight unless it was at least 18'. And at 18' you had no room for anything but the car. I went with a 20' enclosed (20' interior and 24'overall) and it give me "just enough" space to store a few things on the way to the track. The optimal size if I had it to do over would have been a 24' interior.
Enclosed aluminum trailers (with alum floor) are expensive but the weight savings really matter when towing.
GT3 player par excellence
OR, you can get triple axel and big truck and wt distrubtion hitch with anti sway bars. then voila.....
i just drive the thing in and go. i dont can also load unload without trailer hitched.
BIGGER IS BETTER. go for it.
