TPMS in a 996 GT3
Would it be possible to install the Tire Pressure Monitoring System in a 996 GT3.
I know it could easily be done from the tire side, but that's of course not all there is too it. Although not fully accurate it would still be a nice tool to have especially for track use.
Admin
I am using one for the last two years. It's nice. Fast refresh rate; faster than 1st gen oem GT3. Super easy to install and measures temperature too. : )
Ditto Slow, I've got the exact same and it's perfect, can't fault it, you can even hard wire through the back of the console/ radio.
Admin
Looks great, but my friend google also showed me this option. Good thing about this alternative is that you do not need sensors inside the tire but just a cap. Anyone experience with this one: http://www.tyredog.com
Admin
Really accurate!
And the best part with the temp sensor is that once you link the ratio between inner tire air temp and outside tire temp. ( *I mean an absolute average one, not for camber purposes) you can see when tires are up to temp or when they are getting too hot.
Great for R tires or tires that get greasy when hot like the 888s or tires that can kill you when cold like the non N cups. : )
