DIY Brake Flush Question
A simple job the should cost you less that $30 of Motul RPF600 and an hour of your time. Buy a Motive Power Bleeder. With it, once you have each wheel off, flushing each corner becomes a 5 minute job.
GT3 player par excellence
bleed it like any other car. two ppl method or motiv bleeder.
I put mine up on 4 stands so I can have all 4 wheels off and then it's a 15 minute job for the whole shootin' match. Pax Rear, Driver Rear, Pax Front, Driver Front. Outer nipple then inner on all.
Buy a motive power bleeder and it makes the process VERY easy for 1 person. Just make sure you have enough fluid at all times in the bleeder.
Assume the fluid is like acid on any painted or coated surface. Cover everything first and don't spill or drip.
no kidding. i didn't and what a major PIA to fix it.
I did that ONCE, just once, and that was all I needed to learn from. I opened the clutch bleed valve and got fluid on my hand and couldn't get the valve tightened and ALL the fluid went through plus a nice amount of air. Now I have 2 liters at all times in the bleeder. Maybe overkill, but great insurance!
