Which gear oil do you use? Mobil Mobilube PTX, Shell Transaxle, other?
Both are the 2 approved tranny oils as listed by PCNA. However, the reason I ask is that the current PET catalog lists the Mobil Mobilube PTX as the ONLY gear oil for the 04-05 GT3 and the Shell Transaxle for all the rest of the 9X6 line.
I am getting ready to do my first tranny oil change and was hoping to draw from the experience some of y'all may have experienced.
So....Mobil PTX, Shell, Other?
TIA!
TIA!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Dell,
I would recommend this:
http://www.lufteknic.com/Merchant2/m...ode=lubricants
Rennlist member 'bgiere' deserves the thanks for finding it.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Dell,
They also have some nice GT3 parts as well:
http://www.lufteknic.com/Merchant2/m...egory_Code=gt3
Originally Posted by CME
What does Porsche use. Had it changed recently by local dealer. Should have asked.....
Chet
Chet
I will probably just pay the dealer to change it since I imagine the labor is about 1 hour. Totally worth $100 permium to NOT have to do it.
Thanks for the link Lewis. I'll check into it.
Originally Posted by Phokaioglaukos
Check the thread HERE.
Note that post #13 has some hard data on the Porsche-approved oils and the copper corrosion inhibitors that the LSD wants. It took me some time to find that data!
This can be a religious topic, so I'll say no more.
Originally Posted by enthusiast
I believe the factory fill lubricant is no longer available and that started the Rennlist debate.
Originally Posted by OldGuy
Is there a posted DIY on this- On renntech I only see the rotor engine oil and air filter DIY's
thanks
thanks
Dave, the Mobil site only lists the commercially available products at your local Auto Zone, etc.. The "factory rec'd" stuff is ordered through the dealer. The Mobil1 75-90 is probably VERY good for a car without LSD like the GT3, but I have heard from some others that tried it and the LSD did NOT perform as it should have. I will be using the Mobillube from my dealer.
Interesting Dell, further research has turned up a couple of sources that say Mobilube SHC 75W-90 is the OEM fill for the GT3, RS, and cup car. The Mobil site, however shows that it's been discontinued and replaced by Mobil Delvac Synthetic Gear Oil 75W-90
I'm about ready to throw up my hands and visit the dealer for this stuff, and return the Mobil 1 I purchased. It was $10 and change from Kragen... I wonder what the dealer charges for the "correct" fluid?
Dave
Dave
Here in Sweden we only have the SHC and a SHC LS that is the same but for limeted slip
What model do you guys recomend
