996 GT2/GT3 Forum 1999-2005
FS: Complete set RED GT3 calipers
Old 05-08-2006, 01:05 PM
996's Avatar
All I need to have those GT3 piston front calipers on my 996TT is calipers, 2pc. rotors and pads? The GT3 steels rotors will not fit? if so, how much are the special 2pc. rotors be? TIA
Old 05-08-2006, 11:17 PM
roberga
roberga's Avatar
A local Pagit dealer told me that their pads are not the same as the Porsche pads. Porsche now makes 2 for the PCCBs. Black P-40 for street and such. THhe greens are motorsport pads. They will wear faster and when they get to about 50% left will fracture and perhaps have chunks break away.
Old 05-08-2006, 11:34 PM
bora
bora's Avatar
Why not ping pagidusa directly and ask?
Either way, I have heard horrible things about the performance of the green pads at Laguna Seca (worn out in one day), that I am keeping away from them.
Old 05-10-2006, 01:38 AM
996's Avatar
I've found some pics of Pierre's TT. He is fitting the 350mm 6 pistons BBK. They look like GT3 6 pistons calipers and the rotors looks like OEM parts. Can anyone confrim are they GT3 steels rotors? TIA
Old 05-10-2006, 10:14 AM
viperbob
Former Vendor
viperbob's Avatar
You can absolutely bolt on the calipers and 996 Cup rotors or stock GT3 rotors to your TT. As I mentioned, they will be 2 mm offset to the inside. You even have to be careful with the play in mounting them that the face of the rotor does not touch pin at the bottom of the caliper that the pad slides on. Also if you get too low on pads, the front pad will no longer be seated on this and will twist with the force of the rotor as there will be nothing but the top pin keeping it from simply dropping out of the caliper. So can it be bolted on? Yes. Is it a good idea? Not at all.
Old 05-10-2006, 03:23 PM
996's Avatar
Thanks Bob, I've also talk to Pierre. He also told me is not simple direct swap with GT3 rotors. So can you PM me the price of the 2 pc. rotors fit with this setup your mentions before? TIA
Old 05-10-2006, 05:16 PM
bora
bora's Avatar
I have a buyer for these brakes with check in the mail.
Thanks for your interest.
Quick Reply: FS: Complete set RED GT3 calipers
