GT3 sway bar settings
What have you guys running a stock set up found to be the best sway bar settings front and back? Did yours come tightened all the way down from the factory?
Basic Site Sponsor
Basic Site Sponsor
Best for what? I liked mine one hole from hard (front & rear) for autocrossing, and would soften the rear bar one more hole for less oversteer for the track.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Still plays with cars.
I agree with Larry. Same setup on my car.
I run the same setup at the track: 1 from stiff front (stock setting), 1 from soft rear (1 softer than stock).
Autocross, I run full soft front and rear. As the autocross tires wear out, I move the front bar to 1 from soft, then middle. When I reach the front stock position for autocross to keep the car balance, typically the rear tires are shot and due for replacement.
Street: same setup as the track, with exceptions when I'm lazy to set them back from an autocross.
My car runs an aftermarket suspension. On the stock suspension I ran stock rear and full stiff front.
What are the alignment specs that are being run with those settings above? Also does anyone know what the compression and rebound rates are on the stock gt3 shocks ? I am curious what the simular sitting would be in Pss9 terms
I guess the stock gt3 springs are:
Front: 280 lbs progressive
Rear: 550 lbs progressive
Pss9's are? and gt3 dampening rates are?
Rhymes With Polo
Which way is hard, and which way is soft. I've left mine as it came???
Basic Site Sponsor
Basic Site Sponsor
Full hard is the hole closest to the cross bar, and full soft is the hole farthest from the cross bar. If you think of the "ends" as a lever that twists the cross bar, this will become apparent.
trj - going stiffer in front increases understeer. Going stiffer in the back increases oversteer.
The exact stock GT3 spring rates as published in Pano:
F: 40 N/mm linear
R: 95 N/mm progressive
I was told 280lbs/in - 550 lbs/in by the german tuner that sold me my camber plates. For several reasons, I trust them. Using a conversion to lbs/in on the published numbers in Pano, we get 228.44 / 542.55 which can be rounded to 228/543 or 230/540 or 225/550.
There is a good article on the 996 Suspension on this link
F: 40 N/mm linear
