What sort of shifter and cable setup is this on my 6-GT3?
The original owner of my car had the shifter and cables upgraded in around 2012 or 2013. The service records receipt that I have does not say what type/brand of cables were installed, just that a 997 shifter was installed along with "cables". I have been missing 3rd sometimes on the track so I pulled the center console today to adjust the cables and found these.
The left (side to side movement) cable is labeled GT2 (as you see in the photo) and has a standard coupling. The right shift (fore/aft) cable is not like any I have ever seen.
There appears to be no adjustment at the transmission end on either cable.
It appears it was setup on a standard 997 (non-GT3 shifter) (P/n on the shifter is 997 424 010 00), however with this cable it has a very short throw and feels like a GT3 short shifter, even though it's not.
Not sure how to adjust the right one. I installed my Porsche locking tool and adjusted the left cable per the normal procedure.
Anyone recognize what this setup is?
Thanks in advance
Thanks in advance
That looks to be the old style evo machined coupler. It is an improvement over the stock plastic piece which is prone to breaking overt ime. However the design leaves a little bit to be desired in my opinion. I found one of those on mine too. The way you adjust it is by backing out the set screws and then adjusting the cable inside the coupler to where you want it and then tighten the little screws back in again with an Allen key extremely tight. They literally must dig into the metal of the cable end.
Sorry for the silly question but what are you looking to achieve by adjusting the cables? Is there anyway the “slack” can be taken out of the cables? My cup cables have a little bit of play before they “take up the slack” (for want of a better description). Is there anyway to tighten this up or is this due to wear and tear? My father’s 996 GT2 does not have any play in the cables at all and it feels fantastic.
apologies for OT
apologies for OT
