996 GT2/GT3 Forum 1999-2005
What is the spec / spacing for the crank trigger
Old 02-05-2019, 06:11 PM
rbahr
rbahr's Avatar
Default What is the spec / spacing for the crank trigger
With a LWFW. is it 1.0mm or .8mm?
ThanksRay
Old 02-06-2019, 09:08 PM
StephenB
StephenB's Avatar
Ray,
You probably already have this but the info I have is for the stock flywheel: 1.0mm +/- 0.2mm
Not sure if LWFW would have a different spec, unless aluminum
Old 02-06-2019, 10:01 PM
rbahr
rbahr's Avatar
Thanks,
I had found that number, but for some reason thought that the LWFW may have a different value.Ray
Quick Reply: What is the spec / spacing for the crank trigger
