996 GT2/GT3 Forum 1999-2005
Question about gearing.
Old 12-03-2018, 06:34 AM
spiller
spiller's Avatar
Default Question about gearing.
Hi all,
I know quite a few of you have played around with the gearing on these cars.
If one is to fit a cup car 4:1 final drive to a 996 GT3, does this make the gearing taller, shorter or the same as the 996 cup car? I understand the 996 cup has a close ratio box. On the weekend I ran a circuit in my cup car for the first time but when comparing this weekend’s in car footage to previous footage of my 996 GT3 (with 4:1 R&P fitted) at the same track, the gearing in the street car appears to be noticably shorter than the cup car. I do not know for sure what is in my cup car but I’d like to assume it retains the factory cup gearing.
Any pointers on this topic of which I have limited understanding would be great.
Cheers
Old 12-03-2018, 07:08 AM
spiller
spiller's Avatar
Never mind, I found the answer to my question in this thread over on piston heads...
https://www.pistonheads.com/gassing/...f=48&t=1114130
For those who might find it interesting, below are the speeds in each gear at 7000rpm
996.2 GT3: .1st-41mph,..2nd-73mph,..3rd-101mph,..4th-130mph,..5th-157mph,..6th-184mph
996 Cup: 1st-45mph,..2nd-70mph,..3rd-96mph,....4th-106mph,..5th-127mph,..6th-153mph
996.2 GT3 with 4:1 final drive: 1st-34mph,...2nd-63mph,...3rd-83mph,...4th-106mph,...5th-130mph,...6th-152mph
So the 4:1 swap makes the 996 GT3s 1st, 2nd and 3rd gears significantly shorter than the 996 cup with 4th, 5th and 6th being quite similar to the cup car.
I dont have the specifics on rpm drop between gears for each scenario but in my experience of driving both 996 GT3 (4:1) and 996 cup on track, there doesn’t seem to be a huge difference in rpm drop between the two cars. The ring and pinion change closens up the ratios quite nicely in the street car. I’ve got to say I prefer the shorter gearing that the street car + 4:1 change offers. The cup car gearing feels too long by comparison!
Old 12-04-2018, 02:53 PM
GTgears
GTgears's Avatar
There’s a mistake in your numbers/ratios. 3rd gear on both a street car and a cup car was 1.56 25:29 for 996. Only 1st and 2nd will be shorter on the street car once you fit a 4.0.
Old 12-04-2018, 04:53 PM
spiller
spiller's Avatar
So the speeds in 3rd should be the same between the two? Interesting as the footage I have of the two cars is fairly representative of the numbers I came across.
Old 12-04-2018, 08:43 PM
GTgears
GTgears's Avatar
I figured it out. It's the delta in tire size. It's the only possible answer if those numbers are based on 7000rpms like mentioned on Pistonheads.
Old 12-05-2018, 02:44 PM
rbahr
rbahr's Avatar
This may help. I ended up changing my gear set as opposed to the Final.
Ray
Old 12-05-2018, 11:06 PM
spiller
spiller's Avatar
Ah yes, that makes sense now! I was only a few tenths quicker in the cup car than I was my street car (old rubber on the cup probably did not help) but the car just felt like a dog getting off the really slow corners compared to my experience 2 years earlier.
Old 12-05-2018, 11:09 PM
spiller
spiller's Avatar
Ray
What have you done ray, fitted the cup gear set to your road car? I suspect it would be quite nice with the small street tyre on the back but with the 680 slick on the rear of a cup car I feel it’s a touch too long. Porsche wanted something that would work well everywhere though so it’s always a compromise. The layout on the weekend was far from the norm so not going to get too caught up on it. I just wanted to see if there was some “sense” to what I was feeling out on track.
Old 12-06-2018, 08:54 AM
rbahr
rbahr's Avatar
What I did was:
1st gear: 3.82 996 TT
2nd gear: 2.05 996 TT
3rd gear: 1.56 996 GT3
4th Gear: 1.308 Cup
5th Gear: 1.094 Cup
Ray
6th Gear: .912 Cup
R&P stock
Ray
Old 12-06-2018, 10:14 AM
Nickshu
Nickshu's Avatar
What I did was:
4th Gear: 1.308 Cup
5th Gear: 1.094 Cup
6th Gear: .912 Cup
R&P stock
Ray
Interesting that you stuck with the stock GT3 3rd gear...At this point in my "track journey" I find that 3rd gear is too low, especially on an uphill exit when I am carrying too much speed for 2nd, in 3rd it bogs a little and I don't feel like i have the torque I'd like in 3rd. If there's a single gear I would want to change on the car it would be 3rd. Maybe I just need to carry more speed to get higher RPM's in 3rd...LOL...Like I said - At this point in my track journey - Always learning and trying to get faster and smoother.
Watching this thread with interest.
Old 12-06-2018, 11:09 AM
rbahr
rbahr's Avatar
Hi Nick,
Let me say that my 3rd selection was not made after much deliberation. But then, because 2nd gear is a bit longer than stock - I am using the TT mainshaft, 3rd is never a problem for me. My biggest problems were 4th, 5th, and 6th, which I replaced. I had considered the R&P, but could only afford the gear set or the R&P, and decided to go for the gears. It would be easier to change the R&P later. I was also concerned about the accelerated wear of the 4.0 R&P
Ray
Old 12-06-2018, 01:06 PM
KOAN
KOAN's Avatar
I know it is theoretically true, but has anyone had any personal experience with accelerated wear with a 4.0 R&P?
Old 12-06-2018, 09:35 PM
spiller
spiller's Avatar
I have never experienced a 996 GT3 with stock gearing as my road car had the 4.0 fitted by the previous owner. But, comparing it to my cup car and based on the numbers I posted above, I can see how you would find 3rd to be too long as the cup car is too long (2nd is too IMO) and the street car is longer yet again. It takes forever to rev out to 8, so much so that I get impatient and shift at 7500 lol. This gearing is not at all suited to tight tracks. It bogs down out of slow corners and you’re just waiting waiting waiting. Yes, these are momentum cars and the revs need to be kept up at all times but there is only so much of that you can do when you’re running slicks with 15+ heat cycles on the rear and there are multiple 25 mph turns . My advice is to fit the 4.0 R&P and not mess with the stock gearing otherwise. It’s cheaper and easier and it really livens up the car. It’s not a perfect set up but it beats the heck out of stock.
i will see if I can do an overlay video of my fastest lap
in the road car with the 4.0 upgrade versus the cup car.
Old 12-10-2018, 10:13 PM
spiller
spiller's Avatar
I lack the skills for overlay but the top video is my 996.2 GT3 with the 4:1 final drive change. The bottom video is my 996 cup with factory cup car gearing.
You can see how much quicker the road car gets off the slow corners with the shorter 1/2/3 gearing. Granted this is an unusually tight layout.
Old 12-11-2018, 09:54 AM
KOAN
KOAN's Avatar
Spiller,
Great examples of the differences. Thanks for posting. It must be interesting switching back and forth between RHD and LHD.
You seem to have both cars set up for understeer. I know some people prefer that. I prefer of bit of oversteer.
What are your sway bar settings?
Quick Reply: Question about gearing.
