Flimsy OEM gas pedal! – Replacement alternatives?
Hi to all, as I’m sure many who track their cars regularly find out, the factory gas pedal is flimsy re-both it’s construction and stability. Certainly not helping with effective heel and toe.
The only replacement option I’ve found is this quality item from TARETT $325
What are most people doing re this issue?
Anyone fabricated something directly?
Cheers.
https://www.tarett.com/items/996-997...x-3-detail.htm
Cheers.
Rennline fully adjustable gas pedal. Highly recommended. Makes heal/toe soooo easy.
Edit...I guess same one is sold by Tarett, looks identical to your link there from Rennline or Tarett.
Basic Sponsor
Ira
www.Tarett.com | Sales@Tarett.com | 858.674.5573
Check out our new Suspension Package Designer
Basic Sponsor
I've been contemplating a fix of this lately for mine as well, it has the Rennline adjustable pedal part installed but has some rock as yours does. Might have to add the Tarrett base in the near future.
Instagram :Swine11 | TitanMotorsports
Swine11 ReBoot - 964 / 993 Shift Boot Trim Panel
2004 996 GT3 | 1986 Carrera 3.2 (future Keen Project) | 2016 Cayenne Diesel
Ira, can you please advise shipping cost to Perth 6000 Australia, in cheapest option in no rush to receive, many thanks
Hi again guys, perhaps I’m wrong but in fact I think the products are quite different? The Rennline item completely replaces the factory pedal, the Tarett unit compliments it but still uses part of the factory item? Happy to hear any clarification! Thank you
Rennline also sells a cheaper alternative that screws on top of the original plastic pedal and has screws that allow a little height adjustment. This model is completely different from the fully adjustable model. You cannot add the fully adjustable base to the "screw on top of the plastic pedal" type. They are completely different products.
Hope that clears it up. I have owned both versions... The cheap "on top" version which honestly is mostly for looks (it doesn't adjust much) and the complete fully adjustable model.
Basic Sponsor
The fully adjustable gas pedal sold by both Rennline and Tarett are completely identical. Exactly the same product. You must remove the original pedal from the car, disassemble it, cut it, then install the original plastic pedal case over the fully adjustable pedal. It requires cutting plastic, cutting a little carpet on the right side of the pedal area, and drilling I think one hole in the footwell area.
The fully adjustable one made by Rennline is amazing. Sounds like the Tarrett may be the same. It was one of the first things I replaced in my car, because the pedal hinge was broken and cobbled together by a prior owner. Highly recommended.
