996 GT2/GT3 Forum 1999-2005
What brake line sizes are on the GT3 master cylinder
Old 09-19-2018, 08:38 PM
powdrhound
powdrhound's Avatar
Received 1,701 Likes on 991 Posts
Originally Posted by GVA-SFO
About Boxster circuits :
Well, I can confirm with 100% that my 2001 Boxster S, (OEM) has the rear circuit outlet of the MC in M10 !
(front outlet is M12)
May be is because of PSM, as the 10mm outlet goes to the passenger side, to the PSM pump.
Yes, the PSM Boxsters use a 12/10 MC. It's the non PSM cars that have 12/12
Old 09-19-2018, 08:40 PM
powdrhound
powdrhound's Avatar
Originally Posted by Nickshu
Good info I will order one and get rid of the adapter. Thanks for the info. It looks like the part number for this line is 996 355 313 04. I will order one and report back.
That's the one..
Old 09-19-2018, 09:47 PM
rbahr
rbahr's Avatar
Hi John,
I would like to see a picture. The ABS unit is just not in the budget at this point... Sounds like you have a very good setup there.
Are you running 18" rims with those rotors?
Ray
Old 09-19-2018, 11:02 PM
powdrhound
powdrhound's Avatar
Originally Posted by rbahr
Hi John,
Ray
Thats correct Ray. 18x10 fronts and 18x13 rears. I will get you a picture of the pressure transducer on Sunday when I return.
Old 09-20-2018, 04:55 PM
Scott.
Scott.'s Avatar
Yes, please! If you can also include the MoTeC details, that would be great
Old 09-22-2018, 10:48 PM
powdrhound
powdrhound's Avatar
Here is the brake pressure transducer set up I'm running. This is a very clean way of doing it as it avoids any flexible brake lines. This is how Porsche Motorsport did it on their race cars.
It consists of:
1x Motec 2000psi pressure transducer
1x EPDM O-ring (withstands brake fluid)
1x Male 10 x 1.0mm Metric convex seat to 3AN adapter
1x OEM brake line banjo fitting (914.355.531.00)
2x OEM copper crush washers (904.355.902.00)
1x OEM Porsche Motorsport 12mm banjo bolt (993.355.517.80) - * No longer available
The PM banjo bolt is unfortunately no longer available so I had several of these manufactured based on exact measurements I took off of the original part. Essentially it is an exact replica of the PM part machined out of stainless steel. I do have a few extras of these if you decide to go this route.
Hope this helps...
Old 09-23-2018, 06:47 AM
Scott.
Scott.'s Avatar
Thanks! I'll take one of those bolts if you still have them available.
Old 09-23-2018, 09:39 AM
32krazy!
32krazy!'s Avatar
john how much are the bolts?
Old 09-23-2018, 10:25 AM
rbahr
rbahr's Avatar
Hi John,
How much for 2?
Ray
Old 09-23-2018, 11:52 PM
powdrhound
powdrhound's Avatar
Hey Steve, how goes it my friend? When they were still available from PM a few years back they were 78 Euro, so roughly $95. That's what I'll take for one of the few that I have.
Old 09-27-2018, 12:32 AM
powdrhound
powdrhound's Avatar
Hey Scott. I was at the shop and took a few pics of the Motec brake pressure sensor installation. I'm shipping the banjo bolt out to you tomorrow. Cheers...
Quick Reply: What brake line sizes are on the GT3 master cylinder
