New Tow Vehicle
Towing update...did my first long tow today with the GT3 in the back of my 20" ATC trailer. Used a Reese weight transfer hitch, recommend by Lincoln when towing over 6,000 Lbs...up to 9,000. The Good news, the car has an optional trailer tow mode. It provides downshifts when slowing down, kind of handy. Cruise control holds the set speed downhill with no driver input needed. Car felt steady at all times....never exceeded 60 mph. Plenty of power when needed, regardless of the paragraph below.
The Bad News,,,,about 8 mpg on 91 Octane. This was mileage over the hilliest terrain. I think 10 mpg is possible on more level ground. Also,at one point, I was towing up a real long grade, on a 95 degree day, in the south bound "Grape Vine" area of CA Interstate 5. About 1/2 way up the hill, I get a dash board message the engine was going to reduced power to prevent overheating. The main effect, the air conditioner seemed to NOT be blowing cold air for a few minutes...the power was more that adequate to maintain 60 mph. Transmission oil temperature never exceed 215 degrees F. Engine oil and coolant were normal...well at least they didn't throw a warning.
Overall, the 2017 Lincoln Navigator Reserve with "L" option, appears to be a great tow vehicle.....and with the "L" stretch version, plenty of room, and an awesome sound system. The Cruise control is operator friendly, very easy to resume the cruise speed after breaking...just hit resume and away you go. I never drove the Cadillac Escalade of the Surbuban, or Denali. They could be better, or perhaps worse.
Last thing, in the Trailer Haul mode, on deceleration, you get automatic down shifts..right down to 1st gear.
2015 GMC Sierra Denali - never missed a beat towing all over the country. Trailer brake controller built in, Anti-sway built in, trailer tow mode handles downshifts and senses downhills. 12mpg with a 22 foot ATC. That reduced power message would worry me a little.
"That reduced power message would worry me a little." It worries me too...I am going to dig into what caused it. I have an appointment today*** at the local Lincoln dealer. We'll see how that goes. I hope it is a simple fix....if they stone wall me........I'll have to make some tough decisions.
***They moved me to 9/13/18, the Tech person who booked the appt. was very helpful. She thinks that something is definitely amiss. If they find the problem, and can fix it, I'll keep the Lincoln. If not, I am selling it/trading its in....probably on a Denali or Suburban.
If I decide to sell the car, I'll have a giant crow to eat, but it won't be the first time.
Is this motor a new/different from Ford's 3.6TT. Just found out that the Ford 3.6TT in raptors and trucks is a dual port injection so no carbon intake in valves. Toyota's V8s are also dual injection motors which should be reliable power plants.
I've been thinking a few times of buying a tow vehicle and appreciate you eliminating the Navigator.
If the Reduced Power dilemma is addressed by Lincoln, and it is discovered it is a sensor error, then the Navigator will keep its place in the driveway. If it is not successfully resolved, it will be sold and replaced with a GMC Denali, or Chevy SUV.
The Lincoln is in for "surgery" today. I should have the diagnosis this afternoon....Witt Lincoln in San Diego, incredible service, sent me home in an Uber car at their expense, and will deliver the car to my home this afternoon. Now that is service. I will have an opportunity to talk to the service tech re the diagnosis and remedy.
BTW, the net effect of the Reduced Power mode, shutting off the air conditioner for about 10 minutes....I felt no loss in power.
Dealer called me back...discovered to codes in the ECU, one bing over heating. If there is not a simple fix, I asm calling "John Wilkes Booth" to take this bitch out. Clear the codes and put it on the block.
I know on the Expedition you need to order the tow package to get the cooling, etc. needed for serious towing. Same for the Lincoln? Does yours have it?
Finale
Got the Bad News....the reason for the over-heating, blown head gasket, my local Lincoln dealer Witt Lincoln, San Diego, they will replace both head gaskets, one due to a failure, and the other precautionary, under warranty. Once it's fixed, I'll probably sell it, trade it and get a Suburban or a Denali. I can't live with a vehicle that overheats and displays no warning, a vehicle whose coolant gauge never indicated anything but normal.
So pass over that CROW. Yummm..
