996 GT2/GT3 Forum 1999-2005
Steel to PCCB
Old 05-27-2018, 01:03 AM
jmla
jmla's Avatar
Default Steel to PCCB
The car currently has factory installed steel rotors, I have acquired a set of ceramic rotors and calipers. Would this be a direct bolt-on or do I need to source some additional parts? I thought I read that the uprights are different?
Thanks in advance!
Old 05-28-2018, 11:01 AM
Autoquest Motorsport
Former Vendor
Autoquest Motorsport's Avatar
Thanks in advance!
Assuming you have a GT3 based off your signature, what year is it? Also, are those PCCB rotors new or used? If used have they been weighed/measured within spec for carbon content?
Old 05-28-2018, 01:18 PM
jmla
jmla's Avatar
Hi John,
The car is an '04 GT3, the PCCB set up has less 1k street miles, no track time.
Old 05-28-2018, 05:37 PM
Former Vendor
Hi John,
PM sent
Old 05-28-2018, 06:45 PM
enthusiast
enthusiast's Avatar
Why are you doing this?
Old 05-28-2018, 07:40 PM
cgfen
cgfen's Avatar
Thanks in advance!
I think that it is a direct bolt on since you have the appropriate PCCB rotors and calipers.
Test fit one of the fronts to be sure.
Enjoy.
Old 06-01-2018, 05:00 PM
vilfredo
vilfredo's Avatar
Good decision. I went the other way round and occasionally regret it. If I could afford it, I would go back to PCCB.
At least I have only replaced the rotors and kept the inner mounts to keep the great look and feel of the PCCB.
Old 06-02-2018, 09:17 PM
cgfen
cgfen's Avatar
I'm typically not a fan of black wheels, but BRAVO, well done.
Is the rear wing painted or wrapped?
Cheers
Craig
Old 07-19-2018, 11:11 AM
RacingBrake
Former Vendor
RacingBrake's Avatar
Pccb stock replacement rotors:
https://www.racingbrake.com/category-s/7571.htm
Old 07-19-2018, 11:24 AM
Nickshu
Nickshu's Avatar
Is the master cylinder the same on PCCB vs. nonPCCB? If different it would be easy to swap, just something to consider.
Old 07-21-2018, 01:42 PM
Backmarker
Backmarker's Avatar
Good thread. I drive my GT3 about 1000 miles/year and am losing the heavy iron rotors I installed for the track years ago and am going back to the PCCBs. I have ceramics on my other 911 and love the feel, the low unsprung weight, and no dust!
Quick Reply: Steel to PCCB
