Front Caliper Pin
Front Caliper Pin
Well, I noticed my caliper pin/rod was sticking out and the pad is slightly off so I can't just push it back in.
Does anyone know what keeps the pin in place, like Alan screw? I have not heard of this pin coming out in the past.
I can take the pads out and push the screw back in, but want to know how it will stay in place.
Any thoughts on the picture and what keeps the pad rod from moving? It looks like there is a hole under the rod with maybe some kind of screw that either backed out or got dislodged.
Saw it, can’t help you. Not suppose to do that.
The slotted spring pin (roll pin) where the yellow points looks to have either failed or fallen out.
Check the remainder of the pin isn't snapped off in there, then get a pair of verniers to establish the depth and diameter and order a replacement off these guys :
https://www.spirol.com/s/roll_pins_g...RoCq7gQAvD_BwE
or any local engineering supplies shop.
Yes, I believe you guys are correct! It helps to see the other side of the caliper. I will check this weekend to see if part of the pin still exists or backed out.
Does anyone have any extra one? I am guessing it will be difficult (trial and error) to find the exact size.
Thanks again,
Rodney
Thanks again,
Rodney
Chuck? $100 for caliper pin? Not for roll pin. If rear is same as front I'll knock it out and send it to him. 2 on caliper undamaged. don't ask what happened that I have this mangled caliper.
Hey if you could send the rear ones that would be very helpful. My guess it front and rear would be the same and at worst it will be a good reference.
