Piston to cylinder wall clearance
Hi All,
I am interested in knowing the wear limits and clearance numbers for piston to cylinder wall, for 3.6l & 3.8l, cup and street. Been looking in the documentation and have been unable to find these numbers.
Ray
Ray
Not sure if it helps Ray, but I looked at a set of Mahle Motorsport pistons and liners that we are using on my engine rebuild and it shows a difference of 0.08mm between the piston O.D and liner I.D. These are not OEM but Mahle makes the OEM stuff so the clearance is likely similar.
