Looking into a 996 GT3
I am new to Porsches all together but I have owned my fair share of E30 M3's and now I'm looking to make the move into the Porsche world. I am looking at a 2004 Porsche 996 GT3 in Houston Texas (Link attatched). What are the common issues with these vehicles and what should I look for or request from the dealer?
https://www.porschenorthhouston.com/...AC299X4S692903
If you're serious about the car you would normally arrange a PPI, pre-purchase inspection, from some local knowledgeable Porsche guru.
That should uncover any major shortcomings. PPI's run a few hundred bucks. I paid a little more since there was a concern about the engine in mine, so I had them get compression.
If you plan to take the car to a track, you need to have the coolant lines pinned or welded. (The PPI would tell you if that's been done, but probably not if the dealer is not advertising it).
These coolant lines can come loose and spill antifreeze on a track, causing cars behind you to spin out, so as I understand it's a requirement these days if you want to go to the track.
That's an engine-out procedure that runs $3K-$4K, but the problem is that while you're in there, you might as well do a bunch of other routine things.
For my car, we upgraded the factory limited slip to a Guard LSD (another $4K+), since the factory limited slip is not really that robust and doesn't really work well after some use.
There were a lot of routine things (43K miles on my car) that were done; throw-out bearing, myriad hoses and seals, water pump, coolant reservoir, plugs and coils, rear main seal, transmission and motor mounts.
There was also a very minor oil leak that was not visible until things were apart that was fixed; front fender liners were cracked and so those got replaced.
The clutch and pressure plate were fine.
With 60K miles on your car, you'd want to check out service records as much as possible to see how much of this routine stuff has already been done.
Just beware the slippery slope if you pull the engine out to do the coolant lines ... all the other stuff adds up very rapidly.
As for GT3’s in general, many (read virtually everyone) pins or welds their coolant pipes. It’s so hot here in Houston, I only run water + wetter, so I didn’t do mine. I’ve had 2 crap out in just under 10 years. 2004 cars are running up on 15 years old, so there are going to be a lot of things that need to be checked. As mentioned, mounts, hoses, belts, suspension, etc etc. Track cars need a little more TLC to keep them going strong. Engine should be fine as long as readout has no meaningful Range 2 overrevs.
In terms of track speed, the 996 GT3 is maybe a second slower than a 997.1 GT3, same driver, same track. If you upgrade your suspension, you get that second back (+some). About another second slower than 997.2 GT3. It’s easily a couple seconds+ slower than the 991.1. Everyone will tell you that it’s all about the experience. 996 GT3 is raw and visceral. Every iteration above it is more watered down. What you lose are creature features making it more daily usable. Not to say it can’t be driven on the street. But the 991 GT3 vs 996 GT3 on the street is like comparing a Serta mattress with a yoga mat.
If you are really a track fanatic, the 996 GT3 will reward you in ways not many other cars will. But if you think it’s more of a street/weekend ride, you might thrown in a 997.2 turbo or even a Audi R8. Or, get another Porsche for the commute
-td
Google the vin and you will see this was a track car in a previous life. Last sold in 2015 witih 56,796 miles. No Type 2's then.
There is a rennlist thread on it.
Some excerpts:Hey guys, we have just traded for this 2004 911 GT3 in Guards Red over Natural Grey.
The car has only 56,792 miles and is in impeccable shape with no paint work or accidents.
The car has a roll cage installed, so would assume some track use but you can't tell by looking at the cars condition. I have provided a clean DME in the pics.
The car will be offered up for $69,991 obo and I will replace the iphone pics with professional pics soon.
Please feel free to PM, call, text or email with any inquiries..
Pranqster
Thanks to everyone that replied! I do not plan on tracking the car so the welded or pinned hoses shouldn't be a concern for me. This will be just a fun weekend, cruiser for me. sorry if that disappoints any of you guys. lol
I googled the car's VIN and read the thread from 2015, can someone please break down the DME read out for the over rev. What are the numbers in Range 1? did it over rev 4,000+ times?? I'm sure that wasn't the case which is why I am looking for a better understanding of this. Thanks
Anyone ... correct me if I'm wrong but this is how I understood the DME report for the 996 GT3.
Range 1 essentially means it hit the rev limiter, 8200 RPM, which is not considered a problem.
The number reported,4462, is the number of ignitions recorded. At 8200 RPM there are 420 ignitions per second, so there were somewhere around 10 seconds of it bumping the rev limiter.
The hours value, 1863, means the last event happened 1863 hours ago, which is a long time. In fact it seems a little too long ago.
Maybe the 1863 hours is the total number of hours.
Range 2 means the RPM exceeded 8800 RPM I believe on the 996 GT3. This can happen when you downshift into the wrong gear; the rev limiter will not protect you then.
Range 2 over-revs are concerning since there is the potential for internal engine damage.
A more boring color, and who knows the history but it’s under 40k miles and negotation starts at $65k
https://www.cars.com/vehicledetail/d...1139/overview/
(no affiliation)
https://rennlist.com/forums/vehicle-...ual-socal.html
I have had one fitting come loose over time. When it is time to replace the clutch (still on its original clutch) I'll have the remaining fittings addressed.
My point is, don't think that simply using it as a street-only toy avoids the need for addressing the fittings. Even the Turbos fail on the street.
The good news is that losing a fitting on the street is more of a significant nuisance than a potential safety issue on a closed track driving at 9/10ths.
As others have said, the car is raw, but I just see it as a true sports car. Regular 911s are simply too sedate in my book, but that's just my personal opinion. Your opinion is what really matters.
Are you a E30 M3 SIG Member. I am and have an Evo3. Transition from E30 M3 to 996 GT3 is seamless.
Chet
Chet
Drive one for a bit if possible first to make sure it's the right choice for you.
I am 95% street and only 5% track and one is STILL the right choice for me.
Have fun.
It looks good in red, I haven't seen many of those.
