996 GT2/GT3 Forum 1999-2005
235 or 245 on 8.5 front - Wets
Old 02-08-2018, 08:59 PM
Matt Lane
Matt Lane's Avatar
Default 235 or 245 on 8.5 front - Wets
I run 245 and 305/315 on my E88s for track. I picked up a second set of wheels for rain/cold and will probably run something like a SuperSport or the comparable Conti Extreme Contact Sport that will allow me to salvage driving in really bad weather including a return drive from home - those times when it's just not worth trailering up track tires.
The OZ are stock 8.5 front size. I will probably run a stock 295 rear to minimize contact patch in the wet.
For the front, would you run 235 or 245? Both sizes seem measured and spec'd for an 8.5 inch rim.
The 245/40 will better match height-wise with a tall 295/35 (which is all that's available in the Conti, no 295/30 spec).
Thanks for your thoughts.
Cheers
Matt
Old 02-08-2018, 09:26 PM
993GT
993GT's Avatar
for wet weather, was very surprised how well the compound updated Pzero Rosso's do...
am running 245/40 on 8.5" (RT615K+)
Old 02-09-2018, 02:33 PM
Matt Lane
Matt Lane's Avatar
Thanks Rob.
Cheers
Matt
Old 02-09-2018, 05:49 PM
cgfen
cgfen's Avatar
go for the 245's
they will fit without rubbing and give you a bit more grip.
I don't see any downside to them over the 235s
enjoy!
Old 02-09-2018, 07:17 PM
Matt Lane
Matt Lane's Avatar
Yeah, I think I'll do that.
Cheers
Matt
Old 02-16-2018, 02:32 PM
stuttgart1
stuttgart1's Avatar
245 will rube the inside when you make u turn or tight turn. Hope this helps.
Old 02-16-2018, 05:56 PM
993GT
993GT's Avatar
^ totally alignment/setup dependant..
Old 02-16-2018, 10:59 PM
Matt Lane
Matt Lane's Avatar
Yup, I am already running 245's.
The only issue was alignment which requires castor pucks to keep the front wheels back when lowered..
Cheers
Matt
Quick Reply: 235 or 245 on 8.5 front - Wets
