996 GT2/GT3 Forum 1999-2005
Pin vs Weld? Now I know why most pin
Old 01-18-2018, 02:15 PM
cgfen
cgfen's Avatar
Default Pin vs Weld? Now I know why most pin
Once at this point of disassembly, it's pretty easy (pinning) access to the pipes that need attention.
To weld, the <water pump housing> and the <connection piece & belt tensioner bracket> need to be removed.
The more that is removed, the more joints that might leak when I re-assemble
Sigh
Decisions / Decisions.
A good weld jobs solves both catastrophic failure and small leaks.
Pinning just solves catastrophic failure.
rear engine view access
Water pump housing
Connection piece and tensioner bracket
Old 01-18-2018, 02:44 PM
AudiOn19s
AudiOn19s's Avatar
Not to be a party pooper...but taking the front of the motor off to get all of those fittings off to be welded is much easier than taking the upper intakes off to get down to the last 2 lines that are located under the oil cooler on the top of the motor.
Old 01-18-2018, 02:54 PM
F1CrazyDriver
F1CrazyDriver's Avatar
While you're in....
IMO weld. I have had mine welded for ~4 years now. 20k miles. 0 issues with the car.
Refresh hoses, gaskets, etc while motor is off. I think total for me was ~7k but i basically refreshed everything.
Not warranted or needed however at that point she was ~5 years old so why not show a little love.
Old 01-18-2018, 03:03 PM
996FLT6
996FLT6's Avatar
^ I think I was there at thill when it grenaded. Mike
Old 01-18-2018, 03:15 PM
cgfen
cgfen's Avatar
Yeah, haven't dug down that far......................
Old 01-18-2018, 03:32 PM
Gofishracing
Gofishracing's Avatar
grenaded? I never heard of these engines doing that-
Old 01-18-2018, 04:03 PM
F1CrazyDriver
He means when pipes went.
Mike i think you were, it was very late in the day, ~4:30 pm, a mooty day, low volume of cars. Hose went off front straightaway at thill. I saw it instantly ( i was looking at my rear view mirror the whole front straight to see the mustang) and pulled over.
Bad part i was playing cat and mouse w/ another vehicle luckily we were taking different lines. Flag workers saw it instantly and other vehicle was the only one behind me. Being a mooty day, no other cars within a mile. Other bad part is i reach ~130-40 front straight. Car had 26k miles, first track day ever for the car(not the driver), do not be fooled it wont go for low mile cars!
Old 01-18-2018, 07:32 PM
996FLT6
996FLT6's Avatar
Mine grenaded too but on a different day. Thank god for both events nothing happened. Mike
Old 01-19-2018, 12:00 PM
pranqster
pranqster's Avatar
There are many advocates for both methods (welding and pinning).
I had mine re-glued and then pinned.
To me it appears as if the welding is very difficult to get correct.
Weak spots equals possibly catastrophic coolant spill.
Pranqster
Old 01-19-2018, 12:49 PM
mmuller
mmuller's Avatar
Pranqster
This is very true on the welding if re-using the Porsche sleeves, which I would not recommend.
If you use aftermarket sleeves like these from BBI -> https://www.bbiautosport.com/product...hf7rcwmmm43kww
Then you have more shoulder to weld with and end up with a very stout weld/connection because there is a bigger shoulder with better metal to make it right.
It won't fail if done this way.
Old 01-19-2018, 02:57 PM
Marv
Marv's Avatar
Pranqster
That would be one hell of a bad weld for the whole fitting to break off. A pinhole leak might be an issue, but a complete catastrophic fail of the weld seems next to impossible to me.
I guess you could make a case that drilling the holes for the pins are risky, too. For one, getting 100% of all the aluminum chips is not easy. Two, you could lose a pin.
Old 01-21-2018, 02:56 PM
Backmarker
Backmarker's Avatar
Funny I also lost coolant at Thunderhill, not so funny was Mikmyu was behind me in his green .1 RS. Scary but no harm ultimately. There's a video on youtube somewhere.
In my case a hose burst, wasn't a factory glue failure. This was with ~20k miles and dozens of track days.
Old 01-23-2018, 01:59 PM
porschedog
porschedog's Avatar
I know I need to weld mine but I need to find a shop I actually trust to do it right and for less that $56 zillion
Old 01-23-2018, 03:20 PM
Gofishracing
Check with your local PCA group- they can head you in the correct direction. I'm still disappointed I could not get NHTSA to do an actual recall. I REALLY tried. But it is very important for cars taken to the track be fixed. I also replaced all the rubber hoses. Heinlein Racing even safety wired them as well. Beautiful work. Remember - these cars are now 14 years old.
Old 01-24-2018, 03:04 AM
911mhawk
911mhawk's Avatar
I pinned and did JB around joint to prevent weeping:
Quick Reply: Pin vs Weld? Now I know why most pin
