996 GT2/GT3 Forum 1999-2005
Fuming in my own juices: Coolant Pipes
Old 02-02-2018, 09:18 AM
  #76
Rootwitch
Rootwitch's Avatar
She's a beaut, you'll love it. My 15% tax on purchase should make you feel better
It does, a little bit, thanks
Old 02-02-2018, 10:48 AM
  #77
AudiOn19s
AudiOn19s's Avatar
Originally Posted by Rootwitch
It turned out the car has a fairly new OEM clutch with p/n through 997.2 GT3. The clutch does not have springs - what is the significance of that?
Clutch for dual mass FW does NOT have springs.
Clutch for single mass DOES have the springs
In the dual mass setup the flywheel itself functions to keep down NVH and clutch chatter. The springs on the clutch for the single mass try to take up that functionality from at least the clutch chatter standpoint. You can't get away from the noise of the single mass.
Old 02-05-2018, 10:53 PM
  #78
spiller
spiller's Avatar
I loved the noise of the SMF (not to mention the fun of rev matching with it). One of the best bits about the car. Every GT3 should have this.
Old 02-05-2018, 11:08 PM
  #79
Rootwitch
Rootwitch's Avatar
Something tells me that I also would not mind or might even like the noise of the SMF, even though others kind of warned about it for a mostly street car.
Old 02-12-2018, 12:40 AM
  #80
vandersmith
vandersmith's Avatar
I loved my LWFW at the track. Absolutely loathed it around town.
Feels great stalling on a Seattle hill.
In rush hour traffic.
With your track numbers on the sides.
Multiple times.
Went back to Dual Mass and never regretted it.
Track only cars should definitely have one. Rev matching is insane.
Old 02-12-2018, 08:47 AM
  #81
AudiOn19s
AudiOn19s's Avatar
Multiple times.
I"m assuming your C4 had an aftermarket flywheel and clutch setup?
The OEM lightweight flywheel for the GT3 (8.5 lbs for the 4.0 unit) coupled with the OEM clutch setup is almost identical from a driveability standpoint to the dual mass setup.
Old 02-12-2018, 11:49 AM
  #82
Martin S.
Martin S.'s Avatar
Originally Posted by 996TWINS
The 997TT rear discs are a direct bolt on for the 996 GT3 rears, when going from ceramic to steel discs.
997 352 406 02 right rear
997 352 405 02 left rear
Sebro has a slotted version which are really nice. # 909384C (right rear) and # 909383C (left rear)
I will be at the Speed Gallery camp in Feb.
996TWINS dispenses some good advice. In the process of removing my PCCB rotors and pads, I installed the Serbo set up on the rear with Pagid pads, awesome. On the front I installed GIRO 2 piece rotors with Pagid Yellows.
Quick Reply: Fuming in my own juices: Coolant Pipes
