996 GT2/GT3 Forum 1999-2005
engine coolant hose "schematic"
Old 12-08-2017, 09:54 PM
cgfen
cgfen's Avatar
Default engine coolant hose "schematic"
silly me, I thought that I would order some replacement coolant hoses prior to actual engine drop next week.
intention was to R&R likely failure suspects.
Porsche Katalog isn't much help.
It shows many coolant hoses, but gives no indication where they "live"
help me with a pointer or drawing that shows coolant hoses on the engine orientation?
Katalog lists these images
Craig
Old 12-09-2017, 03:32 PM
powdrhound
powdrhound's Avatar
Received 1,721 Likes on 1,003 Posts
Can you post the complete schematic with the part numbers on the right? I just ordered a bunch of hoses and used the 996Cup pet which is a lot clearer as to the orientation. I can try to cross reference the part numbers.
Old 12-09-2017, 10:17 PM
ewj
ewj's Avatar
When I got my coolant lines welded, this is a list of the hoses that I replaced:
996-106-477-75 WATER HOSE SU 1
996-106-529-73 COOLANT HOSE 1
996-106-250-74 HOSE, WATER P 1
996-106-512-74 WATER HOSE 1
996-106-233-74 WATER HOSE 1
900-181-064-51 RUBBER HOSE 1
Old 12-10-2017, 01:17 PM
black04
black04's Avatar
Default PET, Fiche with all 996 GT3 water hoses noted, highlighted
As Powderhound noted, the OP and I were using the Wrong PET,
Per Powderhound request, here is the GT3 Fiche with the diagram and part numbers highlighted. I needed this for my own use as well.
Note; This does not answer the OP's original question, to the effect, "is there a way to actually visualize where the hoses are located on the engine"
I labeled the fiche with descriptions such as "Water Pump" and "Radiator", but I am not sure what "Water Cooling #1" means. Maybe those are the hoses around the engine. And "Water Cooling #2" looks like Under Body
I don't know if I am lucky or what, but I've only replaced one water pump hose in 50K miles and 12 years, so I am not familiar with the cooling system.
18 hoses total on the fiche, which jibes with my 2004 GT3 search on the Pelican Parts website
http://www.pelicanparts.com/catalog/..._pg2.htm#item6
I wonder which ones are not replaceable without removing the engine? There must be several hard-to-reach around the engine, including the ones that attach to the coolant pipes that require pinning/welding
Note that none of the part numbers in the above " got my coolant lines welded " post match the part numbers on this 2005 PET. They must all be superseded. The current number should come up when any supplier inputs these numbers. I just tried one of the old numbers (the one hose I replaced) into Pelican parts search bar and it came back with the new number.(I had to close a Chat/Help window to view the new number)
Last edited by black04; 01-02-2018 at 10:52 AM. Reason: Wrong Attachments, Additional information
Old 12-10-2017, 01:22 PM
black04
black04's Avatar
Default Replacing ALL Hoses
Why only those? Are those the ones that can only be replaced with the engine out??
The Pelican Parts catalog lists 18 different hoses that I see, including the two water pump hoses. BUT... I do not know if this list is a mixture of Engine, Underbody, Radiator and Water Pump hoses.
The Pelican pictures do seem to better depict the actual shape of the hoses.
Old 12-10-2017, 01:47 PM
powdrhound
powdrhound's Avatar
Black04, the problem you have is the fact that you are looking at a 996 PET and not a 996 GT3 PET. The parts are totally different. Something didn’t look right initially and it makes sense now.
Old 12-10-2017, 08:23 PM
cgfen
cgfen's Avatar
check your pm
Old 12-10-2017, 08:26 PM
cgfen
cgfen's Avatar
Thanks for the feedback.
I'll check out Pelican Parts site.
It looks like the only katalog that I have is the 996 one, not GT3 specific.
Cheers
Craig
Old 12-11-2017, 01:16 AM
Gadsby
Gadsby's Avatar
Fyi, there are errors in the 996 gt3 pet and alot of updated part numbers dealer will need to convert to latest version. Also dont forget about reservoir, and all those orings while your in there!
Old 12-11-2017, 11:36 PM
cgfen
cgfen's Avatar
Per the OP request, here is the GT3 Fiche with the diagram and part numbers highlighted. I needed this for my own use as well.
Thanks for taking the time to update and post these drawings.
Craig
Old 12-17-2017, 01:42 PM
rbahr
rbahr's Avatar
Here are the cup diagrams...
Ray
frederickcook87 (03-29-2022)
Old 12-30-2017, 01:41 PM
knorrena
knorrena's Avatar
Do the cup parts avoid the need for welding or pinning?
Old 01-01-2018, 01:56 PM
black04
black04's Avatar
That would be a different thread. Try a search on that topic and get back to us. ;-)
Old 01-01-2018, 02:06 PM
black04
black04's Avatar
Good information, but all this begs the OP's original question, "... It (the fiche) shows many coolant hoses, but gives no indication where they "live"
help me with a pointer or drawing that shows coolant hoses on the engine orientation?"
And the answer to that is, "one would have to search for an engine removal tutorial with pictures or video showing all the hoses" and then still, one would have to match up the hoses in the pictures with what is on the schematic.
Even experienced shops probably wrestle with that problem in regard to not only the hoses but other small parts. Parts procurement probably adds days to weeks to a project that the shop could otherwise complete in a day. Makes one understand the meaning of the promise, "we'll get it back to you next week"
Old 01-01-2018, 10:08 PM
cgfen
cgfen's Avatar
ahhhhhhhhh it all makes much more sense now that I've done 98% of the work to drop the engine.
twas a much easier task on my 993.
lottsa h2o tubes on this beast.
Thanks for the help.
Cheers
Craig
Quick Reply: engine coolant hose "schematic"
