996 GT2/GT3 Forum 1999-2005
Chain tensioner left or right?
Old 09-11-2017, 02:05 PM
yelcab
yelcab's Avatar
Default Chain tensioner left or right?
I am posting this question here because all the gear heads are here. On a 997 turbo engine which is same Medzger design as a GT3, there are two part numbers for chain tensioners, one left and one right. I am guessing that one has a design that allows it to be installed upside down and not leak all the oil out.
How can you tell which one is which when you removed them from the car?
Old 09-13-2017, 12:27 PM
yelcab
yelcab's Avatar
Nobody has an idea? How does one tell if one has the right tensioner on the correct side, or not?
Old 09-15-2017, 12:01 PM
Macster
Macster's Avatar
Absent any factory documentation on how to tell the two tensioners apart and my factory service manual has nothing on this -- there's only the part number.
The passenger side and driver side tensioners have different part numbers.
Here's a link you might find of some value:
http://www.autoatlanta.com/porsche-p...section=103-05
Old 09-15-2017, 12:03 PM
yelcab
yelcab's Avatar
And I am not sure if the proper part numbers are scribed on that little $300 part.....
Old 09-18-2017, 11:55 AM
Macster
Macster's Avatar
To which "$300 part" are you referring? The chain tensioner parts in the diagram list for over $500.
If you have the existing parts exposed and if there is a part # visible enter the part # into a google search and see what turns up.
Old 09-19-2017, 11:48 AM
yelcab
yelcab's Avatar
You can get those tensioner for $325 or somewhere around there from a well know Porsche dealer in Oregon
Old 09-20-2017, 06:56 AM
yelcab
yelcab's Avatar
the part numbers are marked on the ends of the tensioners.... so if you take it out, you will be able to tell.
Quick Reply: Chain tensioner left or right?
