Night driving with standard headlights
Straight ahead visibility with the high beams is fine, in my opinion. However there are large dark spots about 30 degrees to the left and right which limit visibility into the corners. These spots tend to make each corner almost blind. I wonder if there is a way to adjust the lights to reduce this problem. Any ideas?
Keeper of the Truth
You should at least have the aiming of the headlights checked. Aiming them properly is the best thing you can do short of replacing them with Xenon's at great cost. FWIW, Porsche's standard Halogen headlights are not known to be more than just adequate.
Official Wednesday AM Red Bull F1 test driver
The Xenons on my car seem pretty good but were aimed low from the factory. Of all the cars I've had, BMW's have always had the best headlights. The M3 I traded for the GT3 had bi-xenons that were fantastic. Even the standard lights on my previous 5 and 3 series bimmers were always superior to any Porsche...
Keeper of the Truth
Still plays with cars.
I agree on three points. The halogen lights on the 996 are marginal. Re-aiming them helps. BWM has the best head lamps.
I checked the headlights this evening. Both the low and high beams have a relatively sharp light cutoff to the sides of the car. I think this is due to the fact that the bulbs are recessed well back within the light fixture, and so light that would otherwise exit to the sides of the car is blocked by the edges of the fender at about 30 degrees to the left and right. Visibility beyond that point to the sides is basically nil. From the drivers position this looks like a big dark spot to the left and right. As a result visibility into tight corners is compromised IMO.
