What Failure Diagnoses Require Engine Drop/Glitter in Oil - Page 7 - Rennlist - Porsche Discussion Forums
Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Reload this Page >
996 Forum
Sponsored by: LN Engineering
Old 01-11-2018, 06:30 AM
  #91
JTT
JTT's Avatar
Originally Posted by tomcat View Post
I could be wrong but I think the bore scoring at the bottom of the bore would be due to piston rocking. If this was the case, then I think you would have ferrous debris from the iron piston skirt coating being rubbed off also.
Iron piston skirt coating?
JTT is offline
Old 01-11-2018, 12:24 PM
  #92
Ahsai
Ahsai's Avatar
Originally Posted by Porschetech3 View Post
What about your thrust bearing? Is it ok? You have not found the source of the metal particles ?
That's a good guess.
Ahsai is offline
Old 01-11-2018, 06:44 PM
  #93
leoj65
User
leoj65's Avatar
Will have the crank carrier apart tomorrow and will post.
Crank turns super smoothly...
leoj65 is offline
Old 01-11-2018, 06:45 PM
  #94
leoj65
User
leoj65's Avatar
They all look in great condition. This is #3 and the dark line corresponds to the location of the scratch/gouge in the cylinder. Otherwise the wear was similar as this.
leoj65 is offline
Old 01-11-2018, 07:20 PM
  #95
leoj65
User
leoj65's Avatar
I was asking about the edge of the pistons where the carbon is missing. Did the piston hit the head?
Just cleaner there for some reason. No head contact.
leoj65 is offline
Old 01-11-2018, 07:28 PM
  #96
TheBruce
User
TheBruce's Avatar
@leoj65 - this is an amazing undertaking. Good on you! Did you attend the rebuild class at Jakes, or just take the online course?
Im excited to see how the story ends :-)
Ps - answered my own question. I saw you post the online class info above. I hope Jake offers more. I think an on demand video would get way more traction than a live webinar.
TheBruce is online now
Old 01-11-2018, 08:25 PM
  #97
leoj65
User
leoj65's Avatar
I think so too. It would be nice if you could go back and revisit areas as you progress.. In the online class it was a tradeoff between taking notes and paying attention, and as I said I missed a bunch due to connection problems.
I think the "taking-apart" part is the easy part compared to the assembly I am sure. I have worked a bit on top ends on single cylinder motorcycles a couple of times, replaced timing belts on cars and such but that's it for technical difficulty.
I will say this engine seems to be designed for assembly/disassembly as it just comes apart in a methodical way with almost all standard tools (a few exceptions). For instance there is only one circlip I have encountered in the whole thing, electrical and other connections are very straightforward with only the power steering lines really being difficult to get to. It's very modular and in most instances all the bolts are the same length and size so there is not a lot of having to keep track of where each one goes, just mark a bag "left head bolts" or whatever and put them all in. For example all the 24 bolts that hold the case halves together are exactly the same size and length. Also no little random springs or other thing shooting out of places as things come apart. There are actually very few moving parts compared to a lot of other engines IMO. Also I was an electronics tech so that removes some of that mystery.
In my whole first time engine removal experience, I broke one plastic cable guide, stripped one bolt on a lifter cradle (didn't fully seat the allen socket when I turned it, came out with easy-out ), and snapped one exhaust bolt to the head. I claim the head bolt wasn't my fault as I sprayed it with lube for a day or two beforehand, and it still wouldnt come out later using a torch and easy out.
I just need to find the source of the glitter the find out if the damage/wear on the few places I have found is fatal, and I will have to decide on the next course of action. probably nickies and possibly pay for someone to assemble the short block. I have confidence in my wrenching but the corporate knowledge part is the unknown. I have used calipers and dial indicators before, and I believe I understand setting end play, but have never done it.... I understand and have used a torque wrench but have never torqued a crank. These are the areas where I waiver a bit.
leoj65 is offline
Old 01-11-2018, 09:02 PM
  #98
TheBruce
User
TheBruce's Avatar
I agree. Its way easier working on my 997 than my Land Rover. The Land Rover has all sorts of magic bolts that are impossible to reach and difference size nuts on the same part for no rhyme or reason.
Excited to see your progress. Whats next on the tear down?
Old 01-12-2018, 08:52 PM
  #99
leoj65
User
leoj65's Avatar
Crank carrier, then clean and inspect everything to look for metal source as it was not blatantly obvious.
leoj65 is offline
Old 01-14-2018, 11:15 PM
  #100
leoj65
User
leoj65's Avatar
Noticed that the #4 valves look different than the others....
leoj65 is offline
Old 01-15-2018, 11:50 AM
  #101
Noz1974
User
Noz1974's Avatar
If you can invest in a good torque wrench that also does angle aswel as torque setting as the bearing carrier, conrod and cylinder head bolts need torquing to a certain value then go further by a set angle , you can use an angle gauge but it's a bit tricky in the can box doing the head bolts as there's not much room!
Noz1974 is offline
Old 01-15-2018, 02:02 PM
  #102
leoj65
User
leoj65's Avatar
Gonna need to buy a larger torque wrench so I will take a look at them!
Thanks!
leoj65 is offline
Old 01-16-2018, 01:08 PM
  #103
leoj65
User
leoj65's Avatar
Thrust bearings. Guess which one faced the clutch.. I have never seen one of these before, is the scoring/gouging normal? Seems like it should be smooth wear. The friction face on the crank it pressed against was totally smooth.
leoj65 is offline
Old 01-16-2018, 01:12 PM
  #104
Ahsai
Ahsai's Avatar
Do you have a pic of the other side of these bearings? I think I saw something...
Ahsai is offline
Old 01-16-2018, 01:15 PM
  #105
Schnell Gelb
Super User
If you Search , you'll find Thrust Bearing issues are mentioned but it seems unpredictable which engines suffer & who knows why?. Mine had perfect Thrust bearings at 90k miles but other items were worn.I speculate it may (like the IMSB) be influenced by manufacturing errrors/misalignment in addition to driver error(riding the clutch) and inadequate maintenance . Be sure to do all the appropriate end float measurements many times and very carefully when reassembling?
Schnell Gelb is offline
Quick Reply: What Failure Diagnoses Require Engine Drop/Glitter in Oil
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
