ABS Failure!
ABS Failure!
During an autocross yesterday, my ABS went out and the OBD says ABS FAILURE and the ABS idiot light is on. I have only basic ABS, no PSM
Brakes work fine, just no ABS.
I have a new found appreciation for ABS. Without it working, its really easy to lock up the brakes.
In searching, it could be a wheel sensor that went bad. I did find some info on testing them with a OHM meter, but there were several values mentioned and I don't know what the correct one is.
Anyone have any thoughts on troubleshooting the problem?
You need to query the system for a fault code, always start with the fault code. You will need more than a generic OBDII code reader to pull the fault code from the ABS.
Once my Durametric finally connected to the ABS system, it showed a 4210 code (rt rear sensor). I also found a P0501 code which appears to be a fault in the same sensor
there ya go..check the wiring and pulse ring for physical damage or debris. Check wheel bearing for looseness, if all looks good replace sensor..
