Starting motor boxter 2002 2.7 liter
Just replace the starting motor works perfect the engine starts and last only 2 second, I put gas and runs with difficult like not enough gas is getting to the engine.
before replace the motor the car was running perfect.
I wonder if I left a hose or cable off
I disconnect the battery to replace the motor
You may want to post in the Boxster forum. The fuel and vacuum lines are probably in a different location than a 996. Someone over there may have experienced your problem.
If you had to remove the alternator to get too the starter motor (as you do on my 996 1999 model) then you may have broken one or more of the small 'very brittle' evap lines, which would cause you all kinds of grief. Hopefully not. Good luck.
