997/996 Key compatibility
I have a set of 997.1 keys from my totaled 997 GT3....Was wondering if I can reuse them. Can you program a 997.1 Key to operate a 2000 996. Same goes for a 997 to 986.
You can't sway the internals form a 996 key to a 997 fob. The switches are I a different configuration
996 - triangle
997 - inline
It may be possible to buy a new 997 fob and have a 996 programmedfor it. I have no idea if the electronics are compatible. Its doubtful a dealer will do it and you pretty much have no choice but a dealer to program a car for a key. In addition to needing a PWIS or PST2, you need to have the double super secrete codes from Porsche
996 - triangle
997 - inline
I have purchased these heads used, on EBay, at different times and swapped my stock key guts/blade into them with no problems. (From a 2003 C2 and 2004 Turbo) Actually I had to file the edge of the blade down to get the lock to engage on one of them. YMMV
https://www.ecstuning.com/b-genuine-...g/00004400083/
For as long as the listing lasts.
http://www.ebay.com/itm/2-New-Replac...3D191053161319
