Clutch squeak?!
Sounds like the noise is coming from under the car. You can remove the clutch slave and lube the end of its rod, where it presses on the release arm. If that doesn't fix it, it's something imside the tranny and dropping it is the only way to lube the components inside.
Thanks Ahsai, the problem actually because quite significant over the weekend the clutch squeak from the underside of the car went away and the pedal stopped returning to the full out position. So I could push it in and get in gear but upon clutch release it would get 3/4 of the way up and stop. I'd have to put my shoe under the pedal give it a small bump and it would spring back. These isn't enough pressure in the line to return the pedal. Could that be the slave, master or both?
Or something inside the gearbox which i'm hoping is unlikely as the box was out under 3,000kms ago and it had all new parts: flywheel, pressure plate, throw out bearing and clutch disk.
Other than the pedal all other gearbox operation was working as it should.
Dan did you read my post #5? I had same symptoms with my car. Only creaked once car had warmed up also. I replaced the slave cylinder first, didn't help but once I replaced the release arm the noise and pedal action was fixed.
Now 8 months later the pedal won't return to full up position, the same as this thread:
https://rennlist.com/forums/997-forum/828511-clutch-problem-pedal-is-kicking-at-me.html
That was resolved by a new master cylinder.
The dealership want to remove the gearbox to find the squeak but I believe that because they reassembled everything with new parts (flywheel, clutch disk, throw out bearing and pressure plate) it should be on them. Not sure how that's going to go.
Anyway the priority at this point is getting the clutch pedal working again and they aren't really diagnosing the culprit, just wanting the drop the gearbox at my expense...
I feel your pain. These cars require an insane amount of money, maintenance and patience to keep running properly. I cant tell you how many parts I've replaced over the last 8 years of ownership including an engine rebuild. AND I still need to replace all control arms. Good luck with diagnosis and hoping the repair goes easy on your wallet.
My parts list continues to grow and its only been 3 years, luckily i've been able to do a few things myself and i'm getting better at it. Also the community is great for advice and knowledge!
I just did the control arms, fronts were easy, rears not so much.
So just an update on this, interestingly there was nothing wrong with the gearbox or the hydraulic system! It was the pedal assembly that was un-lubricated. So the OPC removed it lubricated it and re installed it
Had the alignment done, all good!
Squeak hasn't come back yet, hoping that it never does!
I got this on my previous 996 Carrera Mk2. Got it fixed by the official Porsche workshop here on warranty. The day I sold it I could hear it begin again, faintly. About a year after it got fixed. Only happened when warm and had been driving for some time.
link to thread with videos
I've got a new problem that the pedal wont return, I think its either the clutch slave or master.
Clutch squeek
I get a "chirp" on occasion, but usually when the car is cold. Often times I am at a stop with the car pointing slightly uphill, or when it is damp out. Only seems to happen in first gear. Definitely not the pedal assembly. Anyone else have this experience?
Keith
Keith
- slave cylinder
- pressure plate
- throw out bearing
- internal lubrication of the gearbox
How many kms/miles and how old are the various components?
Quick update, the pedal not coming back up was in fact the slave cylinder (my thought all along!).
Anyway thought this morning that I should have the OPC replace the master cylinder whilst the system was drained but they replaced it before I could ask them to do it
Anyone have any issues with replacing the slave and not the master?
