Starter Motor
Gents, what's the best way to remove the lower starter bolt without removing the alternator?
I'm fairly comfortable with the R&R procedure but when we did this on the weekend we had the alternator removed which provided clear access to the lower starter bolt. I'm not too keen on removing the alternator if I don't have to.
What ways have people gotten to the second bolt?
Also found this image which ill try if I cant get it from above, means ill have to take off one of the pulleys and drive belt. Assuming they use two extensions? One to the starter, a U joint and then one the rest of the way? Would be good to get a torque wrench straight onto that extension.
Anyone know the torque for the pulley that runs off the alternator securing bolt? Might look it up now.
Since you already ordered the new starter, this may not matter. That whine following a cold start is pretty common as the miles add up. Burner's Garage has a good video tutorial for disassembling this starter (same as on a Boxster) and fixing that whine. Might be worth attempting when you get the old starter out to give yourself a good spare.
