996 Forum 1999-2005
A pool of red...
Old 04-01-2017, 10:34 AM
Mark I
Mark I's Avatar
It's coolant. Likely the water pump.
Old 04-01-2017, 12:29 PM
gbakerge
gbakerge's Avatar
The smell is not rank and is essentially neutral, maybe a hint of oak and leather...definitely sweetens up my sweet tea. Thanks for everyone's help, it is coolant.
Now the question is what is the most likely culprit, water pump?
Old 04-01-2017, 12:34 PM
FRUNKenstein
FRUNKenstein's Avatar
If it is leaking from in front of the wheels, then I wouldn't think it would be from the waterpump. That should leak from close to the rear bumper.
Old 04-01-2017, 12:49 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by gbakerge
What is the best way to determine if it is coolant or transmission fluid?
Taste it....if it's sweet, it's coolant...if not, it isn't!
Old 04-02-2017, 08:09 AM
Turbojamie
Turbojamie's Avatar
Coolant for sure, likely a water pump or a hose. Could be the thermostat housing as well.
Old 04-02-2017, 06:58 PM
Kalashnikov
Kalashnikov's Avatar
If it is leaking ahead of the driver's side rear wheel- most likely coolant tank. If it is water pump, get under the car look at the pump. See if it is leaking from the WP area.
Old 04-02-2017, 08:47 PM
ZuffenZeus
ZuffenZeus's Avatar
Received 1,664 Likes on 918 Posts
Man, you're fooling us aint ya?... that's really a urine sample.
Looks like you've been drinkin' too much coffee these days.
Old 04-02-2017, 09:53 PM
wildbilly32
wildbilly32's Avatar
If that is a urine sample he needs to get to a urologist...STAT!
Old 04-10-2017, 10:48 PM
gbakerge
gbakerge's Avatar
It was coolant. Apparently a small plastic part that separated the coolant tubes broke and this resulted in the tube rubbing on metal and wearing a hole in itself. Problem fixed and off and running again. Still can't get enough of the cat less x-pipe sound...
Quick Reply: A pool of red...
