FOB blinking slowly.. not recognizing?
I think I've dropped my key FOB one too many times. The battery harness came undone (broke?). Anyhow, how I put it together in the key housing, it doesn't work (poor connection I'm assuming). However, when inhave it out and the battery on the circuit board, I click the buttons and it lights up. Battery is new. So I take it by the car and try to unlock it, it's not recognizing. I put it by the ignition and try, still no luck.
It blinks slowly.. on and off. Before, when I pressed it, it would blink very quickly and lock/unlock the car. Whats the issue? How'd it happen all of a sudden? http://imgur.com/emGJAoN |
There are many tricks to getting it to work again, none of which have worked for me. There is a DIY on Renntech for resoldering the chip, that is supposed to work but I haven't tried it yet.
Do a search here for the various methods from reversing the battery to going through a start-up procedure. Good luck. It's amazing that a key fob for a $100k car doesn't work but the one for a VW Bug works every time. |
Originally Posted by wyovino
(Post 14013533)
OP, do some searches and try some of the suggestions. None worked for me, either. |
